PowerMill Forum
Welcome to Autodesk’s PowerMill Forums. Share your knowledge, ask questions, and explore popular PowerMill topics.
Nc code not working
6 REPLIES 6
Emre_Yucel
291 Views, 6 Replies
Nc code not working
Hello, he currently has the current Powermill pro 7.0 and wants to switch to Powermill Ultimate due to system requirements, but when he wants to use the post he is currently using, he gets the errors I have shared the images of, can you help with this? How can we solve the problem, you can connect remotely, good day, good work
6 REPLIES 6
iamcdn79
in reply to: Emre_Yucel
Newer versions of Powermill do not support .opt posts, you have to use a .pmoptz extension. You can find a standard 3-axis Fanuc post located in C:\Users\Public\Documents\Autodesk\Manufacturing Post Processor Utility 20**\Generic called Fanuc.pmoptz. You can try using that and see if it suits your needs.
Intel Core i9 13900KF CPU
128 GB Kingston Beast DDR4 SDRAM
PNY RTX A2000 6GB Video Card
WD 1 TB SSD Hard Drive
Windows 11 Pro
Emre_Yucel
in reply to: iamcdn79
Our machine works with 5 axis logic, when we work with Fanuc in the library, it moves idle and does not move forward as I shared in the video. What do we need to do to run 5 axes?
iamcdn79
You're going to need to contact your technical support and they will need to build a 5-axis post for you
Windows 11 Pro
turgayoWBXFX
Hello. As OguSoft Teknoloji (www.ogusoft.com) we are here to help you Emre. Can you please send us your contact details? Thanks,
a_bako
Have you tried DuctPost 1610?
Old .opt files work with it.
turgayoWBXFX
in reply to: a_bako
As you see on first image, they are currently using .opt PP and having problem. They need to contact us to get help.
