PowerMill Forum
Welcome to Autodesk’s PowerMill Forums. Share your knowledge, ask questions, and explore popular PowerMill topics.
Multiple Entity Export Macro
5 REPLIES 5
evo80
276 Views, 5 Replies
Hi @icse,
I'd like to add models to the Export macro but I get an error at line 146, could you help?
Appreciated!
So I deleted the rogue }
Well spotted by the way!
And this now fires ok.
I now get all sorts of errors from the Import macro??
But it does run through and import the entities.
bool $query = 0
$query = query "Import Entities?"
if not $query {
	return
string $path = "C:/Temp/EntityExport"
if not dir_exists($path) {
	message warn "Project not found"
	macro abort
if length(project_pathname(0)) == 0 OR project_modified() == 1 {
	bool $save = 0
	$save = query 'Save?'
	if $save {
		project save
	} else {
		macro abort
PROJECT IMPORT PROJSELECTOR $path
5 REPLIES 5
evo80
in reply to: evo80
Ok,
Simply turned ERRORS OFF.
Hmmm, that just brings in an empty model.
icse
in reply to: evo80
There was another error not only the missing {
I think you also need to copy the .pmlmz file
	message warn 'Save First'
	return
if dir_exists($path) {
	bool $query = 0
	$query = query "Replace existing Entities?"
	if $query {
		delete directory $path
	} else {
		return
string list $inputTypes = {'toolpath','tool','boundary','pattern','featureset','workplane','model'}
int list $indexer = input choice multiple $inputTypes 'Choose Type of Entity to Export'
entity list $entitiesToExport = {}
foreach $index in $indexer {
	entity list $entities = {}
	SWITCH $index {
		Case 0
			$entities = input entity multiple toolpath 'Select Toolpaths to Export'
			Break
		Case 1
			$entities = input entity multiple tool 'Select Tools to Export'
			Break
		Case 2
			$entities = input entity multiple boundary 'Select Boundaries to Export'
			Break
		Case 3
			$entities = input entity multiple pattern 'Select Patterns to Export'
			Break
		Case 4
			$entities = input entity multiple featureset 'Select Featuresets to Export'
			Break
		Case 5
			$entities = input entity multiple workplane 'Select Workplanes to Export'
			Break
		Case 6
			$entities = input entity multiple model 'Select Models to Export'
			Break
		DEFAULT
			return
			BREAK
	foreach $ent in $entities {
		int $i = add_last($entitiesToExport, $ent)
mkdir $path
//Active entity file
string $activeEntityFilePath = $path + '/active_entity.pmldat'
string $op = '0 1 # Active Entities (DO NOT EDIT!)'
if file_exists($activeEntityFilePath) {
	delete File $activeEntityFilePath
file open $activeEntityFilePath for write as output
file write $op to output
file close output
int $entCount = 0
string $content = ''
foreach $e in $entitiesToExport {
	if entity_exists($e) {
		if $e.RootType == 'toolpath' {
			string $eHash = "x" + $e.ID + ".pmlent"
			string $e_full = project_pathname(0) + "/" + $eHash
			string $path_full = $path + "/" + $eHash
			if not file_exists($path_full) {
				$entCount = $entCount + 1
				$content = $content + $eHash + " pmlEntToolpath '" + $e.Name + "'" + CRLF
			copy file $e_full $path_full
			$eHash = "x" + $e.ID + ".pmlgeom"
			if entity_exists($e.Boundary) {
				$eHash = "x" + $e.Boundary.ID + ".pmlent"
					$content = $content + $eHash + " pmlEntBoundary '" + $e.Boundary.Name + "'" + CRLF
			if entity_exists($e.Pattern) {
				$eHash = "x" + $e.Pattern.ID + ".pmlent"
					$content = $content + $eHash + " pmlEntPattern '" + $e.Pattern.Name + "'" + CRLF
			if entity_exists($e.Tool) {
				$eHash = "x" + $e.Tool.ID + ".pmlent"
					$content = $content + $eHash + " pmlEntTool '" + $e.Tool.Name + "'" + CRLF
			if entity_exists($e.Workplane) {
				$eHash = "x" + $e.Workplane.ID + ".pmlent"
					$content = $content + $eHash + " pmlEntWorkplane '" + $e.Workplane.Name + "'" + CRLF
			if entity_exists($e.Featureset) {
				$eHash = "x" + $e.Featureset.ID + ".pmlent"
					$content = $content + $eHash + " pmlEntFeature '" + $e.Featureset.Name + "'" + CRLF
			if entity_exists($e.Model) {
				$eHash = "x" + $e.Model.ID + ".pmlent"
					$content = $content + $eHash + " pmlEntModel '" + $e.Model.Name + "'" + CRLF
			continue
		if $e.RootType == 'boundary' {
			string $eHash = "x" + $e.Boundary.ID + ".pmlent"
				$content = $content + $eHash + " pmlEntBoundary '" + $e.Name + "'" + CRLF
			continue
		if $e.RootType == 'pattern' {
			string $eHash = "x" + $e.Pattern.ID + ".pmlent"
				$content = $content + $eHash + " pmlEntPattern '" + $e.Name + "'" + CRLF
			continue
		if $e.RootType == 'tool' {
			string $eHash = "x" + $e.Tool.ID + ".pmlent"
				$content = $content + $eHash + " pmlEntTool '" + $e.Name + "'" + CRLF
			continue
		if $e.RootType == 'workplane' {
			string $eHash = "x" + $e.Workplane.ID + ".pmlent"
				$content = $content + $eHash + " pmlEntWorkplane '" + $e.Name + "'" + CRLF
			continue
		if $e.RootType == 'featureset' {
			string $eHash = "x" + $e.Featureset.ID + ".pmlent"
				$content = $content + $eHash + " pmlEntFeature '" + $e.Name + "'" + CRLF
			continue
		if $e.RootType == 'model' {
			string $eHash = "x" + $e.model.ID + ".pmlent"
				$content = $content + $eHash + " pmlEntModel '" + $e.Name + "'" + CRLF
			$eHash = "x" + $e.model.ID + ".pmlmz"
			continue
file close output
string $proj_name = "\" + project_pathname(1) + ".pmlprj"
string $path_full = project_pathname(0) + $proj_name
file open $path_full for read as input
string $line1 = ''
string $line2 = ''
string $line3 = ''
file read $line1 from input
file read $line2 from input
file read $line3 from input
file close input
$line1 = $entCount + substring($line1, position($line1, ' ', 0), length($line1))
string $dest_path_full = $path + $proj_name
file open $dest_path_full FOR WRITE AS output
file write $line1 to "output"
file write $line2 to "output"
file write $line3 to "output"
file write $content to "output"
file close output
evo80
in reply to: icse
Cheers,
That works a treat.
Just a question, why do models need that .pmlmz file to work?
icse
in reply to: evo80
I dont know why,
toolpath's also need an additional file (.pmlgeom)
evo80
in reply to: icse
Yes, I noticed that ext. was different to the others.
Thanks for the help once again!
Technology Administrators
