Multicolour problem
Multicolour problem
chrisKDR3N
Multicolour problem
chrisKDR3N
Hi everyone ,I have a problem about multicolour.
When I use PowerMill 2020 to open this model and use Multicolour shade. It shows only white colour. picture 1 .
But if I use PowerMill 2017 ,it shows the right colour. picture 2.
And I use PowerMill 2017 to save the model , then use 2020 to open. The result like picture 3 .
I use the same Exchange to open.  Exchange 2020.
Please help me check what couse this result?
the model is in this link
https://drive.google.com/open?id=1CWeRQdXcGHT5GomQEW0DUFWhmlfPJtF6
nagamanickam_dharmalingam
Autodesk Support
Autodesk Support
@chrisKDR3N
Thanks for posting your query in Autodesk community,
I have gone through your data, i am able to reproduce the issue at my end also. But when i trying to import other igs (Test)file i could not find the same issue. I think it seems to issue with specific model which you supplied. Are you getting the same issue with some other model also? I request you create a support case from your autodesk account and share the case number for further investigation.
Best regards,
Nagamanickam dharmalingam
Best regards
Nagamanickam Dharmalingam
