Mtd Simulation issue : Post processor is installed but cannot be configured
Alex470
Message 1 of 10
Alex470
We had to reinstall powermill on one of our workstation, since, we have an error when we import a MTD, we get this error : Post processor is installed but cannot be configured.
We didnt have this error before so I've tried to reinstal Powermill 2018 and PmPost multiple times, and it doesn't work.
We have another workstation and we dont have any issue
Any help would be much appreciated
Alex
Replies (9)
Message 2 of 10
iamcdn79
Try running "Make Postprocessor current version"
Intel Core i9 13900KF CPU
128 GB Kingston Beast DDR4 SDRAM
PNY RTX A2000 6GB Video Card
WD 1 TB SSD Hard Drive
Windows 11 Pro
Message 3 of 10
Alex470
I did it before and it didnt work, same when I do "Run as administrator", but thanks
I've tried importing the mtd with every version of PM2018 and Pmpost2018 and I get the same error. I did a clean uninstal of every autodesk product on the cumpter and then reinstal everything and still the same error...
Message 4 of 10
iamcdn79
Does your mtd file have this at the beginning?
<machine xmlns="x-schema:PowermillMachineTool" POST="pmpMultiaxis.*">
Windows 11 Pro
Message 5 of 10
Alex470
Yes, when I remove : POST="pmpMultiaxis.*" it works fine
Message 6 of 10
Chetan.Bankar
Hi @Alex470,
Try checking the exact version of PowerMill and Post Processor you are using on your another system where it works properly. Update PowerMill and Post Processor to the same versions available on the working system and see if it resolve the problem?
Thanks and Regards,
Chetan Bankar
Global Product Support
Submitting & Viewing Support Requests | Web Support | Phone Support
Message 7 of 10
Alex470
Thanks for your help Chetan Bankar,
I just did what you wrote, and unfortunately it didnt solve the problem
Alex
Message 8 of 10
Chetan.Bankar
Alex
Hi @Alex470,
Sorry to hear that you are still facing the problem importing the MTD file into PowerMill. Can you check whether this is happening only with specific MTD or all the MTD. Have you tried importing a simple 3axis machine MTD?
If you are facing this problem with all MTD files then can you try this,
  1. Un-install PowerMill 2018 along with PM Post Processor.
  2. Restart the system and login as an Administrator.
  3. Make sure User account control is set to lowest position.
  4. Reinstall PowerMill & (AMPPU) Autodesk Manufacturing Post Processor Utility ( Normally part of Autodesk PowerMILL install.)
  5. Update the installed PowerMill and AMPPU versions to the recent service patch available for them.
Let us know if you still face problem importing the MTD files into PowerMill.
Thanks for your time and co-operation.
Chetan Bankar
Message 9 of 10
Alex470
So if i use the .mtd provided in the exemple folder it works because POST="pmpMultiaxis.*" is missing, as soon as I write POST="pmpMultiaxis.*" it stops working and I get an error.
I've uninstalled powermill by following the clean uninstall method provided by autodesk, then reinstall everything as administrator and it didnt work. Every time i did an update of PM or PMPost, I tried an mtd file with POST="pmpMultiaxis.*" and it didnt work.
Alex
Message 10 of 10
Chetan.Bankar
Alex
Hi @Alex470,
In this case, can you attached the MTD file you are using here so that I can have a look at it?
Thanks and Regards,
Chetan Bankar
