I have an existing macro that I want to change to move the model to multiple workplane locations instead of just one that I currently have.
This macro works if I just select one workplane but if I select more than one it errors on line
ACTIVATE WORKPLANE $wp.Name
This is what I have currently
STRING yourworkplanename = "G54","G55","G56","G57","G58","G59"
IF ENTITY_EXISTS('workplane', $yourworkplanename) {
//Do Nothing
} ELSE {
GRAPHICS LOCK
// CREATE WORKPLANE AT G54
MODE WORKPLANE_CREATE "G54" INTERACTIVE POINT
MODE COORDINPUT COORDINATES -6.0493 -14.5758 0
// CREATE WORKPLANE AT G55
MODE WORKPLANE_CREATE "G55" INTERACTIVE POINT
MODE COORDINPUT COORDINATES -6.0493 -6.7024 0
//CREATE WORKPLANE AT G56
MODE WORKPLANE_CREATE "G56" INTERACTIVE POINT
MODE COORDINPUT COORDINATES -15.8944 -14.5758 0
//CREATE WORKPLANE AT G57
MODE WORKPLANE_CREATE "G57" INTERACTIVE POINT
MODE COORDINPUT COORDINATES -15.8944 -6.7024 0
//CREATE WORKPLANE AT G58
MODE WORKPLANE_CREATE "G58" INTERACTIVE POINT
MODE COORDINPUT COORDINATES -25.3346 -12.3245 0
//CREATE WORKPLANE AT G59
MODE WORKPLANE_CREATE "G59" INTERACTIVE POINT
MODE COORDINPUT COORDINATES -25.3346 -7.4026 0
UNDRAW WORKPLANE ALL
GRAPHICS UNLOCK
/ ENTITY LIST
ENTITY LIST $Model = INPUT ENTITY MODEL "Select Which Model To Copy To Fixture Offset"
STRING $Newmodel = new_entity_name('model')
STRING $folderFull = "Model\" + $Model.Name
// Allow selection of multiple workplanes
ENTITY LIST $wpNames = INPUT ENTITY MULTIPLE WORKPLANE "Select The Fixture Offsets To Move The Model To"
FOREACH wp IN $wpNames {
// Activate current workplane
ACTIVATE WORKPLANE $wp.Name <----- THIS LINE ERRORS ON ME WHEN NEEDING TO ACTIVATE SECOND SELECTED WORKPLANE FROM INPUT LIST
// Store workplane name for later use
STRING $currentWpName = $wp.Name
IF NOT folder_exists($folderFull) {
CREATE FOLDER "Model" $Model.Name
ACTIVATE FOLDER $folderFull
EDIT MODEL $Model.Name CLIPBOARD COPY
CREATE MODEL CLIPBOARD
TRANSFORM TYPE WORKPLANE TRANSFORM MODEL $Newmodel
DEACTIVATE WORKPLANE
// Unique naming based on model and workplane
STRING $newName = $Model.Name + "_" + $currentWpName
INT $i = 1
WHILE ENTITY_EXISTS('model', $newName) {
$newName = $newName + "_" + $i
$i = $i + 1
RENAME MODEL $Newmodel $newName
EDIT MODEL $newName SELECT ALL
// Check if "Moved" level exists
IF NOT ENTITY_EXISTS('level',"Moved Models to Fixture Offset") {
CREATE LEVEL "Moved Models to Fixture Offset" Level
EDIT LEVEL "Moved Models to Fixture Offset" ACQUIRE SELECTED
DEACTIVATE FOLDER $folderFull
QUIT
Intel Core i9 13900KF CPU
128 GB Kingston Beast DDR4 SDRAM
PNY RTX A2000 6GB Video Card
WD 1 TB SSD Hard Drive
Windows 11 Pro
