PowerMill Forum
Welcome to Autodesk’s PowerMill Forums. Share your knowledge, ask questions, and explore popular PowerMill topics.
Making my macro loop back to the top
5 REPLIES 5
jsweatherbie
741 Views, 5 Replies
I have a drop down menu that once selected it’ll make a drilling program but I need this to repeat cause of different sized drills and such .
I’m not sure how to code it in powermill… is it a  forloop ,while do loop or bool loop????
To sum it up I just need it to go back to the top with a loop.
Tags (2)
Labels (1)
5 REPLIES 5
Sean570
in reply to: jsweatherbie
can you share what you have already? that will make it easier for people to help you out. But my guess is you'll want a while or foreach loop depending on how you have your macro setup
jsweatherbie
in reply to: Sean570
//SHOWS YOU A LIST OF DRILLS
string list options={"0.531 GOLD","0.551 GOLD","0.656 GOLD","0.689 GOLD","0.812 GOLD","0.875 GOLD"}
int i = INPUT CHOICE $options "Choose your GOLD Drill?"
if $I == 0 {
FORM FEATURESELECT
MACRO PAUSE "SELECT A HOLE" + crlf
//531 GOLD DRILL
IMPORT TEMPLATE ENTITY TOOLPATH TMPLTSELECTORGUI "C:/Users/User/AppData/Local/Autodesk/PowerMill/My-Strategies/GOLD-DRILLS/531-G-DRILL.ptf"
RENAME TOOLPATH "1" ".531-G-DRILL"
EDIT TOOLPATH ".531-G-DRILL" CALCULATE
FORM ACCEPT SFDrilling
if $I == 1 {
//551 GOLD DRILL ( NEVER-USED )
if $I == 2 {
FORM FEATURESELECT
MACRO PAUSE "SELECT A HOLE" + crlf +"AND PRESS RESUME"
//656 GOLD DRILL
IMPORT TEMPLATE ENTITY TOOLPATH TMPLTSELECTORGUI "C:/Users/User/AppData/Local/Autodesk/PowerMill/My-Strategies/GOLD-DRILLS/656-G-DRILL.ptf"
RENAME TOOLPATH "1" ".656-G-DRILL"
EDIT TOOLPATH ".656-G-DRILL" CALCULATE
if $I == 3 {
//689 GOLD DRILL (NEVER-USED)
if $I == 4 {
FORM FEATURESELECT
//812 GOLD DRILL
IMPORT TEMPLATE ENTITY TOOLPATH TMPLTSELECTORGUI "C:/Users/User/AppData/Local/Autodesk/PowerMill/My-Strategies/GOLD-DRILLS/812-G-DRILL.ptf"
RENAME TOOLPATH "1" ".812-G-DRILL"
EDIT TOOLPATH ".812-G-DRILL" CALCULATE
if $I == 5 {
FORM FEATURESELECT
//875 GOLD DRILL
IMPORT TEMPLATE ENTITY TOOLPATH TMPLTSELECTORGUI "C:/Users/User/AppData/Local/Autodesk/PowerMill/My-Strategies/GOLD-DRILLS/875-G-DRILL.ptf"
RENAME TOOLPATH "1" ".875-G-DRILL"
EDIT TOOLPATH ".875-G-DRILL" CALCULATE
FEATURESELECT CANCEL
Sean570
I cleaned up the format a little to make it more readable, but you just needed to wrap it in a do-while loop. Let me know if that gets you close enough to what you want.
bool runAgain = false
do {
string tpName = $options[$i]
FORM FEATURESELECT
MACRO PAUSE "SELECT A HOLE" + crlf + "AND PRESS RESUME"
switch $i {
    case 0
        break
    case 1
        break
    case 2
        break
    case 3
        break
    case 4
        break
    case 5
        break
RENAME TOOLPATH "1" $tpName
EDIT TOOLPATH $tpName CALCULATE
$runAgain = QUERY "Drill another hole?"
} while $runAgain == true
jsweatherbie
I’ll check it out soon and thank you very much for condensing it cause I’m no macro programmer nor do I know the language it uses .
jsweatherbie
this runs beautifully thanks for your help im very greatful!
Technology Administrators
