Macro Z values of the flat surfaces
lopezerik73
Message 1 of 17
lopezerik73
Hello.
As title says i want to make a macro for get the Z values of the flat surfaces.
For the moment only have the flat surfaces selected.
Some one can help me to continue ,please?
Many thanks.
kind regards.
Macro:
EDIT MODEL ALL SELECT FLAT
Accepted solutions (3)
Replies (16)
Message 2 of 17
jean-baptiste.bannerot
Hello @lopezerik73,
You want to get the Z values in an external file?
Please try to use the macro in attachment file and say me if it's working as you want.
Regards
Jean-Baptiste BANNEROT
Technical consultant
Message 3 of 17
lopezerik73
Hello @jean-baptiste.bannerot.
First at all thanks for answer.
About get the data in external file is not necesary at all.
But , i have a problem, when execute the macro i have error in line 24 : EDIT MODEL ALL SELECT $Surf.
Don´t know what is the problem.
Many thanks for ty to help me.
Kind regards.
Message 4 of 17
Please can you send me a screen shot of the error box ?
Message 5 of 17
lopezerik73
Sorry, now i test in other part file and works fine. Smiley Surprised
Thanks.
Is posible to sort this values  min to max?
Many thanks and sorry.
kind regards.
Message 6 of 17
Ok perfect.
Yes you can find in the documentation all macro function : "C:\Program Files\Autodesk\<PowerMill version>\lib\locale\C\HELP\Pmill.chm".
You can use extract all value from a list. Be carrefull, the macro used a string list and to extract value you need to use a real list.
Message 7 of 17
lopezerik73
Ok, many thanks.
I think for the moment i use it as you do, because i haven´t enough knowledge for the moment to modify.
Many thanks again.
Kind regards.
Message 8 of 17
Mikhail_Voronin
Hi Jean-Baptiste,
I have a little problem with the macro
________________________________________
Mikhail
Message 9 of 17
Hi Mikhail,
Ok what is the problem ? How can I help you ?
Message 10 of 17
Mikhail_Voronin
If PowerMILL doesn't have an English interface the macro doesn't work
Mikhail
Message 11 of 17
Ok I've find the problem.
Please try with this new version of the macro.
Jean-Baptiste
Message 12 of 17
Mikhail_Voronin
It works fine,
Thank you!
Mikhail
Message 13 of 17
@Mikhail_Voronin don't forget to approve the solution;)
Message 14 of 17
kandennti
Even in non-English interface, it should work.
It is also fast.
function main() {
	//Please set a temporary file path
	string tracepath = 'c:\tmp\sel_surfs.txt'
	EDIT MODEL ALL DESELECT ALL
	string list surfs = {}
	call GetFlatFacesName($tracepath, $surfs)
	if size($surfs) < 1 {
		message warn 'Horizontal plane can not be found!'
		return
	string list zlevel = {}
	call GetZLevelList($surfs, $zlevel)
	string $msg = 'Flat surfaces Z value :' + crlf + join(zlevel, crlf)
	message info $msg
//高さリスト取得
function GetZLevelList(string list surfs, output string list out) {
	$out = {}
	UNDRAW BLOCK
	EDIT BLOCKTYPE BOX
	EDIT BLOCK COORDINATE WORKPLANE
	EDIT PAR powermill.Options.Block.UseReferenceModel 0
	EDIT BLOCK ALL UNLOCK
	EDIT BLOCK TOLERANCE '0.01'
	EDIT BLOCK RESETLIMIT '0'
	EDIT BLOCK LIMITTYPE MODEL
	string list pros = {}
	int dmy = 0
	string face = ''
	GRAPHICS LOCK
	foreach s in $surfs {
		$face = RTRIM($s)
		EDIT MODEL ALL SELECT $face
		EDIT BLOCK RESET
		$dmy = add_last($out, string(round($Block.Limits.ZMin,3)))
	GRAPHICS UNLOCK
	$dmy = remove_duplicates($out )
	$out = reverse(sort($out ))
//水平面名取得
function GetFlatFacesName(string tracepath, output string list out) {
	$out = {}
	ECHO OFF DCPDEBUG UNTRACE COMMAND ACCEPT
	tracefile open $tracepath
	print SELSURFACE
	tracefile close
	ECHO ON DCPDEBUG TRACE COMMAND ACCEPT
	file open $tracepath for read as 's'
	file read $out  from 's'
	file close 's'
	delete file $tracepath
	int dmy = remove_first($out )
Message 15 of 17
jelrod
I think I'm getting the same error @lopezerik73 was. Please see attached. Using version 2018
Message 16 of 17
5axes
Nice solution @kandennti
I would just change in your code the location of the temporary tracefile into   :
	// Temporary file path
	STRING $TraceFilePath = MACRO_PATH(false) + "\Tracefile.txt"
like that you are not dependent of the configuration of your post with a hard coded path.   GetFlatFacesName  could be write like that :
FUNCTION GetFlatFacesName(OUTPUT STRING LIST Surf) {
	$Surf = {}
	TRACEFILE OPEN $TraceFilePath
	PRINT SELSURFACE
	TRACEFILE CLOSE
	FILE OPEN $TraceFilePath FOR READ AS Input
	FILE READ $Surf FROM Input
	FILE CLOSE Input
	DELETE FILE $TraceFilePath
	INT Ret = REMOVE_FIRST($Surf)
herewith same macro with block reset
Message 17 of 17
kandennti
