Macro WHILE query not working when using 'OR'
siwalker
siwalker
I am trying to do a check in my macro that either a radius tool or end mill is selected but I only seem to be able to get it to work when querying one of the two things but when I want it to query both of these things it doesn't seem to work as expected.
Code that doesn't work:
STRING $Tooltypes = entity('tool','').type
WHILE NOT ($Tooltypes == "tip_radiused") OR ($Tooltypes == "end_mill") {
MESSAGE ERROR 'Wrong tool type selected'
MACRO PAUSE "Please activate suitable slot drill" +CRLF+ "for predrill machining"
Also code that doesn't work:
WHILE NOT ($Tooltypes == "tip_radiused") OR NOT ($Tooltypes == "end_mill") {
Code that does work:
WHILE NOT ($Tooltypes == "tip_radiused") {
Also code that works:
WHILE NOT ($Tooltypes == "end_mill") {
If someone can let me know how to fix this or an alternative way of doing this it would be much appreciated.
ondrej.mikulec
WHILE NOT (($Tooltypes == "tip_radiused") OR ($Tooltypes == "end_mill")) {
WHILE $Tooltypes != "tip_radiused" AND $Tooltypes != "end_mill" {
siwalker
Thanks. I thought I was missing something simple. Looks like I just needed some additional brackets.
