Macro to rename shared view
jiri.brany
Observer Observer
jiri.brany
Observer
Observer
Hi. I need help with macro for shared views that renaming view with path directory name.
Thanks.
ken.poyner
Hi Jiri,
there's an issue with the processing for this command, I've opened PMILL-11505 for development to fix this,
thanks,
Ken
Ken Poyner
Software Engineer (PowerMill)
TK.421
Here's part of the macro that I use to do this:
STRING text = project_pathname(1)
STRING viewName = '"' + $text + '"'
STRING myCmd = "SIMPLE_SHARE NAME" + $viewName + "SIMPLE_SHARE ACCEPT"
DIALOGS MESSAGE OFF
ACCOUNT LOGIN FORM fgeCreateShare
DOCOMMAND $myCmd
DIALOGS MESSAGE ON
see if that helps you or not
the numbers never lie
jiri.brany
Observer
Observer
to TK.421
....Very much thank you for the solution...macro works correct...you are king 🙂
