macro to open the paths folder
Felipe_Callegario
Felipe_Callegario
I need some help for this macro, currently it is used to activate a toolpath, I would like that when activating the toolpath it expands the folder where the toolpath is located.
STRING LIST $names = extract(folder("Toolpath"),"name")
INT LIST $Choices = INPUT CHOICE MULTIPLE $names "Choose_Toolpats"
FOREACH tpn IN $Choices {
ENTITY tp = entity("Toolpath",$names[$tpn])
ACTIVATE TOOLPATH $tp.Name
STRING LIST tpathFolders = extract(folder("Toolpath"),"name")
STRING LIST tPaths = {}
$tPaths = extract(folder("Toolpath"),"name")
STRING first = $tpathFolders[$i] + "\" + remove_first(tPaths)
STRING last = $tpathFolders[$i] + "\" + remove_last(tPaths)
// Select all the toolpaths in the folder
EXPLORER SELECT TOOLPATH $first NEW
EXPLORER SELECT TOOLPATH $last SERIES
kevin.hammond3WX4X
Felipe_Callegario
Thanks for your solution, but it's still not what I need, as I use a lot of folders in my project, I want to open only the folder of the tool that is active
kamalrajcv
To achieve the desired functionality, you can add the following lines of code inside the loop after the "ACTIVATE TOOLPATH" command:
// Get the folder entity of the current toolpath
ENTITY folderEntity = parent(tp)
// Expand the folder
EXPLORER EXPAND folderEntity
This code will retrieve the folder entity of the current toolpath and expand the folder in the PowerMill explorer. Here is the modified code with the above changes:
Note that the above code assumes that each toolpath is located in a folder. If you have toolpaths that are not in folders, you may need to add additional checks to handle those cases.
Felipe_Callegario
Thank you very much for your answer, but this solution is showing a failure on line 8
kevin.hammond3WX4X
Try this...
STRING path = ""
INT LIST $Choices = INPUT CHOICE MULTIPLE $names "Choose_Toolpaths"
//get folder name of active toolpath
$path = dirname(pathname('Toolpath',Name))
WAIT 1.0
//Message info $path
// Expand the Root folder
EXPLORER SELECT toolpath ROOT
DEBUG EXPLORER KEY RIGHT
//Expand active toolpath folder
EXPLORER SELECT FOLDER $path New
Regards Kevin
Felipe_Callegario
Excellent thank you very much for your solution.
