Macro to change selected tool path model location
evo80
Message 1 of 8
evo80
Good Day,
I'm working on this macro to change the model location of selected toolpaths, but I'm sort of stumped.
Any help would save the remaining hair on top of my head.
IF $powermill.Status.MultipleSelection.First OR $powermill.Status.MultipleSelection.Total == 0 {
STRING $Message = "Choose New Machine Tool Model Location"
STRING LIST Selected_WORKPLANES = INPUT ENTITY MULTIPLE WORKPLANE $Message
DIALOGS MESSAGE OFF
DIALOGS ERROR OFF
GRAPHICS LOCK
FOREACH $tp IN explorer_selected_entities() {
ACTIVATE TOOLPATH $tp.name
FOREACH $ref IN folder ('WORKPLANE') {
EDIT PAR 'ModelLocation' $ref
EDIT TOOLPATH $tp REAPPLYFROMGUI
YES
MESSAGE INFO "All Selected Toolpath Machine Tool Model Locations Have Been Updated "
TEXTINFO ACCEPT
DIALOGS MESSAGE ON
DIALOGS ERROR ON
GRAPHICS UNLOCK
Replies (7)
Message 2 of 8
icse
maby this can help you:
if size(explorer_selected_entities()) <= 0 or explorer_selected_entities()[0].RootType != 'toolpath' {
	return
entity $newWorkplane = INPUT ENTITY WORKPLANE "Choose New Machine Tool Model Location"
DEACTIVATE Toolpath
EDIT PAR 'ModelLocation' ${newWorkplane.Name}
EDIT PAR SELECTED ModelLocation
but it will invalidate the toolpaths
you also could change the last line tho this:
EDIT PAR SELECTED ModelLocation accept
 so no querry apears.
Message 3 of 8
evo80
Thanks for the help,
I didn't have any luck with the code,
Here are the command window results.
Process Command : [entity $newWorkplane = INPUT ENTITY WORKPLANE "Choose New Machine Tool Model Location"\n]
Process Command : [\n]
Process Command : [DEACTIVATE Toolpath\n]
Process Command : [EDIT PAR 'ModelLocation' ${newWorkplane.Name}\n]
Error: Cannot evaluate expression:
newWorkplane.Name
Error: DMG_Attach_Op3
Process Command : [EDIT PAR SELECTED ModelLocation\n]
Message 4 of 8
icse
Thats odd... yesterday i wasnt able to reproduce the error today i got same error
this should work:
	return
deactivate toolpath
string $cmd = 'EDIT PAR "ModelLocation" "' + $newWorkplane.Name + '"'
docommand $cmd
EDIT PAR SELECTED 'ModelLocation'
Message 5 of 8
evo80
@icse
Thankyou very much that works famously for a single selected tool path!
So I edited the code to allow multiple tool path selection, which works fine, the only thing this code doesn't do is have the invalidation message pop up, don't suppose you know how I can include this message?
Not a big deal really, I can live without it, just a fail safe would be nice.
Regards Jon Keeler
Message 6 of 8
evo80
DIALOGS MESSAGE OFF
DIALOGS ERROR OFF
GRAPHICS LOCK
	return
docommand $cmd
DIALOGS MESSAGE ON
DIALOGS ERROR ON
GRAPHICS UNLOCK
Message 7 of 8
icse
it actually should work with multi selection since the line:
should change the parameter Modelllocation for every selected entity
also to show the popup message you should turn em on not off
DIALOGS MESSAGE ON
not
DIALOGS MESSAGE OFF
Message 8 of 8
evo80
Sorry, Your code does indeed change selected tool paths, my mistake.
Thanks for your help, this was something that was taking up a lot of my time, so now being able to select all toolpaths
and changing the model location for different ops has helped tremendously!
Regards
