Macro/Script Assistance
Message 1 of 9
I am  really struggling in setting up a macro (if it is even possible) for this particular application.  Within a project I am wanting to rename toolpaths/folders/workplanes etc by replacing part of the name with alternative text.  Basically on the attached image I am wanting to replace anywhere in the project where the is the text "0001_AD" with something else that will be defined by the user with an input box eg. "0003_AD".  The initial text "0001_AD" will be different in every instance, I was thinking that another user input box could be used to define the text that is to be replaced.  Apologies this is not that easy to explain.
Basically I am looking for -
- A popup user input box for the user to define the text they are wanting to replace (0001_AD).
- Then anywhere this text is featured in the project whether it be toolpath/folder/tool/workplane it is replaced with another item of text to be defined with a user input box.
I have no idea if this in any way possible and was hoping someone out there may be doing something similar already.
Replies (8)
Message 2 of 9
TK.421
you can try the below code.   Copy and paste code for patterns, workplanes, whatever.  this should do what you want, let me know if it doesnt
reset localvars
//set text to replace and new text
STRING oldText = INPUT "Enter Text to Search"
STRING newText = INPUT "Enter Replacement Text"
//loop through toolpath folders
STRING LIST tpFolders = get_folders('Toolpath')
FOREACH fld IN tpFolders {
	IF position(fld, oldText) >= 0 {
		STRING nameOnly = replace(fld, "Toolpath\", "")
		STRING newName = replace(nameOnly, oldText, newText)
		RENAME FOLDER $fld  $newName
//loop through toolpaths
FOREACH tp IN Folder ('Toolpath') {
	IF position(tp.name, oldText) >= 0 {
		STRING newName = replace(tp.name, oldText, newText)
		RENAME TOOLPATH $tp.name $newName
//loop through boundary folders
STRING LIST bnFolders = get_folders('Boundary')
FOREACH fld IN bnFolders {
		STRING nameOnly = replace(fld, "Boundary\", "")
//loop through boundaries
FOREACH bn IN Folder ('Boundary') {
	IF position(bn.name, oldText) >= 0 {
		STRING newName = replace(bn.name, oldText, newText)
		RENAME TOOLPATH $bn.name $newName
the numbers never lie
Message 3 of 9
Works an absolute treat.  Thank you.
Message 4 of 9
ok, so another quick question, am I able to search as above for only folders named the exact search value.  For example, search for "_0001_AD" and only replace the name of folders called this exact name only, as opposed to any folders that have that anywhere in the name eg  it would ignore a folder called "xyz_0001_AD"
I have tried replacing the >= with == and this wasn't the quick fix I was hoping for!
Message 5 of 9
TK.421
I am sorry it isnt working as expected. Are you sure you copied the code exactly? I ask because I tested it with such a case as you're describing before I posted it. As you can see in the screen shots below, I have it working for me.
Could I be misunderstanding you?
Could you post a screen shot of your folders?
Message 6 of 9
It is working as I asked in the first post but since then I have tried to move it on slightly.
In a project I may have multiple toolpath folders -
"0001_AD"
"0001_AD_xyz"
"0001_AD_dog"
I want the macro to search for "0001_AD" and only replace the name of the folder that has that exact same name, thus ignoring the folders "0001_AD_xyz" and "0001_AD_dog".  At present it replaces the "0001_AD" part in any folder name where it sees it (which is what I originally asked for but not what I am trying to do now).
Hope that makes sense.
Message 7 of 9
TK.421
so i did misunderstand your post! try the code below:
reset localvars
	IF $nameOnly == $oldText {
		RENAME FOLDER $fld  $newText
Message 8 of 9
TK.421
is this working for you now?
Message 9 of 9
Yes it works exactly as I wanted, thanky you, you have been most helpful
