Macro Rename Toolpath again
gosmann.andreas
gosmann.andreas
I have a Macro thx to you that renames all toolpath.
What i like to do is that the macro should jump over disc profile finishing strategie. Every other toolpath should be renamed. Is something like that possible.
String $New_Name = ""
Int $Index = 0
FOREACH tp IN FOLDER('toolpath') {
    $Index = $Index + 1
	$New_Name = $Index + " - " + $tp.Strategy + " - " + $tp.Tool.Name
	IF $tp.Strategy == "drill" {
	    $New_Name = $Index + " - " + $tp.Strategy + " - " + $tp.FeatureSet.name + " - " + $tp.Tool.Name
	    RENAME Toolpath $tp.name $New_Name
	} ELSE {
danmic7JH66
You could try adding
IF NOT Strategy == "disk_profile" {
//rest of code
so it will only run the stuff between the { } if the strategy is not a disk profile strategy. Might be a simple work around for you.
rafael.sansao
or:
Int $Index = 0
	IF $tp.Strategy == "disc_profile" {
		CONTINUE
    $Index = $Index + 1
	} ELSE {
Rafael Sansão
OptiNC - www.optinc.tech
danmic7JH66
@rafael.sansao wrote:
or:
Int $Index = 0
		CONTINUE
    $Index = $Index + 1
	} ELSE {
How does the "CONTINUE" command work? Is that any different then just leaving it blank between the{ }?
rafael.sansao
Yes. CONTINUE "aborts" the current loop. See the description in the guide:
Rafael Sansão
danmic7JH66
Ah, thanks, surprised I missed that when I read through. Appreciated
gosmann.andreas
Thank you works fine
