Macro NEED HELP!
Macro NEED HELP!
nlegareLUZKA
Message 1 of 11
Macro NEED HELP!
nlegareLUZKA
HELLO EVERYONE
I WOULD LIKE TO ADD A CONDITION TO MY MACRO 'CHECK_COLLISION'(SEE ATTACHMENT)
AND I DON'T KNOW HOW TO DO IT SO I WILL NEED YOUR HELP.
HERE IS THE CONDITION.
I WOULD LIKE, IF A COLLISION IS DETECTED, THAT THE PROBLEMATIC TOOLPATH BE RENAMMED
'TOOLPATH NAME + _COLLISION' WITHOUT THE MACRO BEING STOPPED.
THANK YOU FOR YOUR HELP AND TIME. IT IS REALLY APPRECIATED!
Replies (10)
Message 2 of 11
icse
try this:
FOREACH tp IN folder('Toolpath') {
	IF NOT tp.Computed {
		ACTIVATE TOOLPATH $tp.Name
		EDIT TOOLPATH $tp.Name CALCULATE
	ACTIVATE StockModel "P#01 - STM_Blank milling_1"
	EDIT COLLISION TYPE COLLISION
	EDIT COLLISION STOCKMODEL_CHECK Y
	EDIT COLLISION STOCKMODEL  "P#01 - STM_Blank milling"
	EDIT COLLISION SCOPE ALL
	EDIT COLLISION SPLIT_TOOLPATH N
	EDIT COLLISION MISS_OUTPUT N
	EDIT PAR 'Verification.UseVerificationThickness' 0
	EDIT COLLISION HEAD_CLEARANCE "600.0"
	EDIT COLLISION HOLDER_CLEARANCE "1.0"
	EDIT COLLISION SHANK_CLEARANCE "0.3"
	EDIT COLLISION DEPTH Y
	EDIT COLLISION ADJUST_TOOL N
	UNDRAW COLLISION
	EDIT COLLISION APPLY
	EDIT STOCKMODEL ; INSERT_INPUT TOOLPATH $tp.Name LAST
	EDIT STOCKMODEL "P#01 - STM_Blank milling_1" CALCULATE
	if Safety.Holder.Cutting.Status == 'collides' or Safety.Holder.Leads.Status == 'collides' or Safety.Holder.Links.Status == 'collides' or Safety.Tool.Cutting.Status == 'collides' or Safety.Tool.Leads.Status == 'collides' or Safety.Tool.Links.Status == 'collides' {
		string $newName = $tp.Name + "_COLLISION"
		if entity_exists('toolpath',$newName) {
			$newName = new_entity_name('toolpath',$newName)
		RENAME Toolpath ; ${newName}
DIALOGS MESSAGE ON
DIALOGS ERROR ON
GRAPHICS UNLOCK
did not tested it...
Message 3 of 11
nlegareLUZKA
Unfortunately, it doesn't work. The toolpath is not renamed.
thanks for the help
Message 4 of 11
icse
Sorry i'm not at my pc ill check it tomorrow.
Message 5 of 11
icse
this should work
	UNDRAW COLLISION
	if $tp.Safety.Holder.Cutting.Status == 'collides' or $tp.Safety.Holder.Leads.Status == 'collides' or $tp.Safety.Holder.Links.Status == 'collides' or $tp.Safety.Tool.Cutting.Status == 'collides' or $tp.Safety.Tool.Leads.Status == 'collides' or $tp.Safety.Tool.Links.Status == 'collides' {
		RENAME Toolpath ${tp.Name} ${newName}
DIALOGS MESSAGE ON
DIALOGS ERROR ON
GRAPHICS UNLOCK
Message 6 of 11
nlegareLUZKA
It still does not work...
Message 7 of 11
icse
Can you explain the problem a bit more.
Does the macro stop at a certain point?
I just tested the renaming part ive added.
Message 8 of 11
nlegareLUZKA
the macro does not stop but the problematic toolpath is not renamed.
Message 9 of 11
icse
For me the code of my last post works fine...
here with all collision checking removed:
foreach $tp in filter(folder('toolpath'),'this.RootType == "toolpath"') {
Message 10 of 11
nlegareLUZKA
Here is the macro rewritten as I think I understood it.
Did I make a mistake? Am I forgetting something?
It's still the same result. It is read to the end without problem,
but the toolpath which is in collision is still not renamed. Thanks again for your help. It is more than appreciated.
Message 11 of 11
icse
try running only this:
i just added my code at the end of your macro
if this works heres the complere macro:
DIALOGS MESSAGE OFF
DIALOGS ERROR OFF
GRAPHICS LOCK
		UNDRAW COLLISION
DIALOGS MESSAGE ON
DIALOGS ERROR ON
GRAPHICS UNLOCK
