PowerMill Forum
Welcome to Autodesk’s PowerMill Forums. Share your knowledge, ask questions, and explore popular PowerMill topics.
Macro help to use active work plane instead of named work plane
4 REPLIES 4
josh.cowley.ctd
211 Views, 4 Replies
I am trying to change a macro to use the active work plane instead of the named work plane.
I have this line
EDIT SETUP SAFEAREA WORKPLANE "1"
I can't seem to find in the guide how to change it so instead of setting the work plane by name "1", it will set safe area work plane to the one that is active?
Thanks for any help you can provide.
4 REPLIES 4
iamcdn79
in reply to: josh.cowley.ctd
Try this
STRING active_workplane = ""
IF ENTITY_EXISTS('workplane', "") {
   $active_workplane = $ENTITY('workplane', '').name
EDIT SETUP SAFEAREA WORKPLANE $active_workplane
Intel Core i9 13900KF CPU
128 GB Kingston Beast DDR4 SDRAM
PNY RTX A2000 6GB Video Card
WD 1 TB SSD Hard Drive
Windows 11 Pro
josh.cowley.ctd
in reply to: iamcdn79
That works exactly as I needed, Thank you!!!
If you wouldn't mind could you possibly add a comment for each line with description of what it actually does?
It would really help me wrap my brain around what the command is doing to help with creating future macros on my own?
iamcdn79
// Declare a string variable named "active_workplane" and initialize it to an empty string
// Check if an active workplane exists
   // If the active workplane exists, assign it to the "active_workplane" variable
// Edit the setup safe area workplane to be the "active_workplane"
Windows 11 Pro
josh.cowley.ctd
Thank You Very Much!!!
Technology Administrators
