PowerMill Forum
Welcome to Autodesk’s PowerMill Forums. Share your knowledge, ask questions, and explore popular PowerMill topics.
MAcro help needed for Project.partname on info tab
3 REPLIES 3
kevin.hammond3WX4X
457 Views, 3 Replies
I want to use a macro to prompt user to enter Customer part number to populate Project.Partname on the project info tab, ultimately looking to expand and include other fields on the info tab.
I dont seem to be able to use a variable to populate this field, can anyone assist please?
String Proj_name = ""
//check if project part name is blank, if so then prompt to name customer part number
If (project.PartName)== "" {
$Proj_name = input "Enter Customer Part Name"
EDIT PAR 'project.PartName' $Proj_name
string new_name = project.PartName
message info "Project is named " + $new_name
Labels (1)
3 REPLIES 3
Use the widget function to get that value. I have powermill 2016 so the widget name might have changed but it should look something like:
string partName = $widget(ProjectNotes.Shell.ProjSettings.PartName).value
Edit: Nevermind, It seems that newer versions of powermill have a parameter associated with this now and so using a widget isn't useful. Rafaels answer is better.
STRING Proj_name = ""
If ($project.PartName)== "" {
	$project.PartName = $Proj_name
	message info "Project is named " + $project.PartName
Rafael Sansão
Thanks Rafael, just what I needed  😀
Technology Administrators
