PowerMill Forum
Welcome to Autodesk’s PowerMill Forums. Share your knowledge, ask questions, and explore popular PowerMill topics.
Macro for changing skim feedrate
3 REPLIES 3
nguyenthinhvt95
725 Views, 3 Replies
Hi all you guys
I have a macro for changing the skim feed rate if the tool type is the drill.
But It takes too much time for activating all toolpath -> checking tool-type -> add to the group.
Does anybody help me to change the skim feed rate without toolpath activate?
Labels (1)
3 REPLIES 3
You can change the rapid feedrate like this:
FOREACH $t IN folder('Toolpath') {
	$t.feedrate.Rapid = 3000
@cfastNJWK6 Thank you for your suggestion.
Base on your idea I already applied it to my macro and it's working well.
Now, It just activates for which toolpath have "coolant == thru" and "skim feedrate > 3000". It save a lot of time instead of activating all toolpath.
Foreach Ncp In Folder ('Group') {
Foreach item In components ($Ncp) {
if $item.coolant == "thru" {
if $item.feedrate.rapid > 3000 {
ACTIVATE Toolpath $item.name
FORM FEEDRATE
EDIT RSPEED "3000"
RESET TOOLPATH FEEDRATE
FORM ACCEPT FEEDRATE
Cobra.007
in reply to: nguyenthinhvt95
This should be even faster
if $item.coolant == "thru" and $item.feedrate.rapid > 3000 {
$item.feedrate.rapid = 3000
Technology Administrators
