PowerMill Forum
Welcome to Autodesk’s PowerMill Forums. Share your knowledge, ask questions, and explore popular PowerMill topics.
Macro for activate and rename toolpath.
6 REPLIES 6
pet.kovacsYHFUD
1359 Views, 6 Replies
Hi.
I just started getting acquainted with macro programming.
I would like to write a macro for activate the toolpath and change the name.
The essence of macro is activate the first toolpath, change the name to the used tool name + any name I can enter in a pop-up window. When this is done go for the next toolpath, activate it and change the name as previously.
Can anyone help me to solve this issue?
Thank you.
Labels (2)
6 REPLIES 6
Sean570
in reply to: pet.kovacsYHFUD
FUNCTION MAIN() {
    // Reset any local variables
    reset localvars
    // Turn off graphics, Dialogs, and error messages
    GRAPHICS LOCK
    DIALOGS MESSAGE OFF
    DIALOGS ERROR OFF
    // Loop through all toolpaths
    FOREACH tp IN folder('toolpath') {
        // grab user input with a popup
        string userInput = INPUT "Enter name for toolpath"
        // Change toolpath name
        CALL ChangeName(tp, userInput)
    // Turn graphics, Dialogs, and error messages back on
    GRAPHICS UNLOCK
    DIALOGS MESSAGE ON
    DIALOGS ERROR ON
FUNCTION ChangeName(Entity tp, string userInput) {
	// create a dummy name for the toolpath
    string tempName = "1"
    // Check that dummy name doesn't already exist
    IF ENTITY_EXISTS('toolpath', $tempName) {
        $tempName = NEW_ENTITY_NAME('toolpath', tempName)
    // rename toolpath the temp name
    RENAME TOOLPATH $tp.name $tempName
    // Start building the new toolpath name by grabbing the tool name
    STRING newName = $tp.tool.Name
    // Add the user input to the end of the new name
    $newName = $newName + " " + $userInput
    // check if the new name exists
    IF ENTITY_EXISTS('toolpath', newName) {
        $newName = NEW_ENTITY_NAME('toolpath', newName)
    // rename toolpath the new name
    RENAME TOOLPATH $tp.name $newName
This should work for you
Try this out:
FOREACH $tp IN folder('Toolpath') {
	ACTIVATE TOOLPATH $tp
	STRING $NewName = $tp.Tool.Name
	STRING $PopUp = INPUT "Enter Name"
	$NewName = $NewName + "_" + $PopUp
	IF entity_exists(entity('Toolpath', $NewName)) {
		$NewName = new_entity_name('Toolpath', $NewName)
	RENAME TOOLPATH $tp $NewName
That was fast. 🙂
Thank you all!
Another variant to play with....
avijitpahari28
in reply to: cfastNJWK6
Can it possible to also add toolpath description
cfastNJWK6
in reply to: avijitpahari28
Absolutely!
    EDIT TOOLPATH $tp DESCRIPTION $NewName
Technology Administrators
