macro command, checking toolpath is cutter compensation is on
t_dueber
t_dueber
I need a little macro to loop through drilling toolpaths (only profile and champfer) and check if cutter compensation is on.
The macro should give a message box with all toolpath where compensation is on.
can anybody help me?
icse
try this:
string $msg = ""
foreach $tp in filter(folder('toolpath'),'this.Strategy == "drill" and this.Drill.Type == "profile" and this.Drill.DepthType == "chamfer" and this.CNCCutterCompensation.Active') {
	$msg = $msg + $tp.Name + CRLF
message info $msg
todd.murphy8YH67
is there a way to tell me what toolpaths use cutter comp, what type and make a list of that ( toolpath and what tool used)
nathanANTQX
I have implimented most of those things into my renaming macro, It does some mathematical calculations based on the hole feature size and what your thickness value is.
Some extra bits of information for us as programmers, and for the shop floor to be able to catch a mistake before it happens.
Variable names it will generate:
HF : Hole feature set diameter from the selected featureset. (not Compound hole ready yet)
PD : Programmed diameter ( hole size + - thickness value for a given toolpath) (profile/helical)
PK : Peck distance for all drilling toolpaths
P : pitch for tapping / Thread milling (from toolpath settings)
RH / LH : Hand of threads ( Tapping and Threadmilling)
Macro Attached
