Losing a variable defined in an IF statement when the statement is finished
Here is the problem:
I am losing the value of a variable I assign in an if statement. I don't know why this would happen.
See example:
INT test = INPUT "enter a number"
if test==5 {
string number = "the number is 5"
As soon as i get out from that if I lose the value number. What am I doing wrong here?
Marc
Accepted solutions (3)
Sean570
I don't think you are losing the number value, just the string value.
try something like:
string number = ""
if test==5 {
    $number = "the number is 5"
// send message to make sure value sticks
message info $number
I found the problem:
I was defining the variable in the if statement:
Resolution:
define the variable outside
update the variable in the if statement
Thank you all
lokesh.kalia
Hi @Anonymous Yes, the curly brackets {} define the scope of any variable declared within them. That is, the variable is destroyed after the closing } bracket. As you've said, for a variable to be used both within the scope defined by the pair of curly brackets and afterwards, it must be defined before that scope begins.
Lokesh Kalia
Senior Manager, Software Development
ChristopherMarion
@Anonymous & @lokesh.kalia
Great information to know.  I'll make sure to remember that rule.
Cheers,
Christopher Marion
Technical Specialist - CAM
SolidCAD - Canada
