PowerMill Forum
Welcome to Autodesk’s PowerMill Forums. Share your knowledge, ask questions, and explore popular PowerMill topics.
Lead-in Lead-out horizontal arc... pleeeease heeeelp!!!!!
4 REPLIES 4
morrysss
705 Views, 4 Replies
Hello
Thank you for entering
I am struggling to make a lead-in and lead-out with horizontal arc, using the 2017 version
I am making a profile on a part with 4 negative corners rad of 6mm
I am machining the all profile with a 20mm cutter and I want to use a 10mm end mill to make the 6mm corners rad
I want to machine only that bit the 20mm cutter left, and do to so I would like to entry and exit the pass with corner rad to avoid marks on the finished profile
What is the difference between horizontal arc and horizontal arc left/right?
I do not know what values to put on:
Linear move?
Angle?
Radius?
Any suggestion according this matter will be very appreciative
Thank you very much in advance for your support
4 REPLIES 4
iamcdn79
in reply to: morrysss
I only use horizontal arc left when climb milling using constant-z toolpath. If I am conventional milling then I use horizontal arc right.
I use 90 for angle and a radius of .05"
Intel Core i9 13900KF CPU
128 GB Kingston Beast DDR4 SDRAM
PNY RTX A2000 6GB Video Card
WD 1 TB SSD Hard Drive
Windows 11 Pro
morrysss
in reply to: iamcdn79
Thank you very much indeed
I was putting the wrong values
morrysss
this answer is exactly what i was looking for thank you
GlennM.MCAM
I always choose horizontal arc (without left or right). It takes the "correct" one when you are climb or conventional milling (at least that is what I noticed).
Glenn
Intel i7 4790 @ 3.60GHz -16GB RAM - Nvidia Quadro K620 - 250GB SSD - Win 7 Pro x64 SP1
PowerMILL Premium 2019.1 - PowerINSPECT Ultimate OMV 2017 SP6
