Join Patterns
Join Patterns
celso.amaral
Join Patterns
celso.amaral
Hello All.
Does anyone know a way to insert several pattersns into one, through a macro?
Tanks
old_snickers
Try it like this:
ENTITY LIST $selected_patterns = INPUT ENTITY MULTIPLE pattern "Select patterns to combine..."
CREATE PATTERN "Combined"
FOREACH $patty in selected_patterns {
EDIT PATTERN $patty CLIPBOARD COPY
EDIT PATTERN "Combined" CLIPBOARD PASTE
celso.amaral
@old_snickers
Thank you very much, it's an excellent option.
Instead of using pick by selection, is it possible join all the patterns inside one folder?
Tahnks
old_snickers
So you want to have a temporary folder, where you can drop your patterns wich you want to be joined per one click?
Create a folder, e.g. named tempfolder_2b_joined. Put your patterns inside it and try this:
FOREACH patty in folder ("Pattern\tempfolder_2b_joined") {
P.S.: if the pattern "Combined" does not exist, it will be created, activated and displayed. If it's already present, the state (active or visible) will not be changed. You may have to add these two lines, if you make sure to see the result immediately:
DRAW Pattern "Combined"
ACTIVATE PATTERN "Combined"
celso.amaral
@old_snickers
Thank you very much.
Works Good.
