PowerMill Forum
Welcome to Autodesk’s PowerMill Forums. Share your knowledge, ask questions, and explore popular PowerMill topics.
Is there any option to check machining limit with existing cutter -holder combination?
5 REPLIES 5
pacecadcam
269 Views, 5 Replies
Is there any option to check machining limit with existing cutter-holder combination?
Prior to generate toolpath one can get proper information of requisite cutter overhang, holder combination and one can adjust the tool overhang well in advance to generate collision free toolpath.
5 REPLIES 5
ondrej.mikulec
in reply to: pacecadcam
You can calculate a "Collision Safe Boundary" for a particular tool to see machinable areas.
iamcdn79
There is no dedicated option for something like that but what I do is set my tool length and holder and make a raster toolpath over my entire model with a large stepover and somewhat large tolerance with Automatic collision checking on with the required holder and shank tolerance and with keep colliding sections turned on.
With this, I can see where there are problem and safe areas. Red = collision area.
Intel Core i9 13900KF CPU
128 GB Kingston Beast DDR4 SDRAM
PNY RTX A2000 6GB Video Card
WD 1 TB SSD Hard Drive
Windows 11 Pro
pacecadcam
iamcdn79 ,
Thanks a lot for the solution.
pacecadcam
in reply to: ondrej.mikulec
Thank you
M_Hennig
Using the Holder Profile option in the tool option page may be the closest thing to help you.
