PowerMill Forum
Welcome to Autodesk’s PowerMill Forums. Share your knowledge, ask questions, and explore popular PowerMill topics.
Is there a way to change machine kinematics settings with script in post processor utility?
1 REPLY 1
Timothy2021
375 Views, 1 Reply
Is there a way to change machine kinematics settings with script in post processor utility or import mtd file with script?
I tried to modify "optfile.Kinematics.MtdType", but it shows the error "read only".
Thanks.
1 REPLY 1
Hello @Timothy2021
the only three functions available for changing something in the kinematics only deal with the axis limits, or initial position.
You can't redefine the kinematic, as the objects does not publicly share functions for changing the values.
(There is only get function, there is not set or put)
The available functions are :
SetDynamicAxisInitial(axis_name, value)
SetDynamicAxisMax(axis_name, value)
SetDynamicAxisMin(axis_name, value)
Cheers
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Serge.Q
Technical Consultant
cam.autodesk.com
