Importing Reference Model from Macro
Greetings All,
I am having some troubles Importing a Reference Model in PowerMill 2019 from Macro.
The Macro Line used is Below
IMPORT REFERENCE_SURFACES "C:\Current Jobs\Shop Fixtures and 3R\3Rmadilla_Ref_model2.dgk"
I have also used it with no success in the Command Window.
The program responds "Error Reading Model, Translator Error"
However if I simply import it from the menu FILE/IMPORT/MODEL then I have no difficulty.
If I use the macro command to import an earlier version of this file I have no difficulties.
How do I go about tracking down this problem?
I have run File Doctor on the problematic model... no errors reported.
Joe7
design
try this:
STRING Filename = ''
$Filename = FILESELECT "Please select a model file" "*.dgk" "C:\Current Jobs\Shop Fixtures and 3R\."
IMPORT REFERENCE_SURFACES $Filename
Vilchez
Thank you!  Hmmn...Very interesting. Why does it work?
I need to load three reference models and then toggle them visible/hidden during macro progress depending on user selection options.
Is it possible to do the above without user input?
Well it seems all my troubles were not actually errors in the file in so much as Errors in my macro that seems to
have discombobulated PowerMill.  So after a few restarts, and a reboot for good measure... I switched to triangles.
IMPORT REFERENCE_SURFACES "C:\Current Jobs\Shop Fixtures and 3R\3Rmadilla_triangles3.dmt"
And I guess my goal of hiding versions of 3 reference models will not be possible... so they will need to be loaded in on demand.
LasseFred
something like that:
STRING Filename = ""
$Filename
bool carryon = 0
string yesnoprompt = "Do you want to blank some models?"
$carryon = query $yesnoprompt
IF $carryon == 1 {
STRING $Model_name = ""
$Model_name = INPUT ENTITY MODEL "Please select that model you want to blank."
EDIT MODEL $Model_name SELECT ALL
BLANK SELECTED
or:
You can make levels for your models.
bool carryon = 0
string yesnoprompt = "Do you want to make some levels for your models?"
IF $carryon == 1 {
REAL levelname= INPUT "Rename level"
CREATE LEVEL ; LEVEL
RENAME Level ; $levelname
EDIT LEVEL ; ACQUIRE SELECTED
i have not tested it....
______________________
Lasse F.
Very cool. thank you!
