PowerMill Forum
Welcome to Autodesk’s PowerMill Forums. Share your knowledge, ask questions, and explore popular PowerMill topics.
I have to include project path in posted program
18 REPLIES 18
Message 1 of 19
karan30782
1215 Views, 18 Replies
Hi ! Everyone !
I was trying to add the parameter in postprocessor like (project path) , but I didn't found it anywhere.
(nc program path) parameter is there in postprocessor setting.
I have to show full path of the project in the posted program.
18 REPLIES 18
Message 2 of 19
cfastNJWK6
in reply to: karan30782
I don't believe that project path is a parameter available in the post-processor.  The project path is available in the Powermill macro language.  You could write a macro that stores the project path as a user parameter and then create a udp_ parameter in the post to get the project path.
Message 3 of 19
karan30782
in reply to: cfastNJWK6
Hello !  cfastNJWK6
First of all _ thank you for your solution..
But I need help a little bit more, actually I'm quite new to post file editing. So I don't know properly "how to create a udp parameter in the post to get the project path"
I will be more thankful if you guide me to set it up.
Please forgive me if I'm disturbing work.
Awaiting your reply...
Thanks again !!!
Message 4 of 19
cfastNJWK6
Go to the parameters tab in AMPPU and right click, then click "Add Standard Parameter".  If you want the new parameter to automatically pull information from Powermill, it has to start with "udp_".  In your case, I would call it "udp_ProjectPath".  Then create a user parameter in Powermill called "ProjectPath".  The value assigned to the "ProjectPath" parameter in PowerMill, will automatically be passed to the "udp_ProjectPath" parameter in the post file.  Then you just have to put the upd_ProjectPath parameter in a comment block in your post for the value to appear in the posted code.
Message 5 of 19
karan30782
Thanks a lot,
But it's still undone.
If you don't mind, could you please connect through teamviewer and help me ??
THANKS IN ADVANCE !!!!!
Message 6 of 19
cfastNJWK6
I'm not able to connect through a live session, but if you upload your post and a sample project I'd be happy to make some edits and send it back to you.
Message 7 of 19
karan30782
Hi !
I have attached the required file with the reply.
I'll be always thankful you are doing to me.
Awaiting reply.......
Thanks !
pradeep30782@yahoo.com
Message 8 of 19
cfastNJWK6
Can you remove the password protection from the post file and re-upload?
Message 9 of 19
karan30782
oh!
so sorry cfastNJWK6,
It's xxxxxx
Message 10 of 19
cfastNJWK6
I have attached an updated version of your post, a macro to create the user parameter, and some pictures for explanation.  First you must run the macro to create and fill the user parameter in PowerMill.  Then post a program with the new post.
I hope this is what you were trying to achieve.
Message 11 of 19
karan30782
Thank you    @cfastNJWK6
Thank you for all you did to help me...
I was trying to do this since last 2 weeks and you did it in just one day..... that was awesome.
The post is working as I was expecting to.
Thanks again & god bless you !!
Message 12 of 19
cfastNJWK6
Not a problem @karan30782 .  I enjoy helping others out with things that I struggled with in the past.  If you could, please accept my last post as a 'Solution' to your post.
Message 13 of 19
shirin.shah
I have gone thru all the above posts and it was indeed very useful for me as I needed to add Part Name from PowerMill to Post output and that is resolved.
However, I also need to use the Project User defined setting value to be outputted inside the NC through Post, how can we set the parameter for that?
Thanks in advance!
Message 14 of 19
rafael.sansao
in reply to: shirin.shah
You must use a udp_ variable in Postprocessor.
Check the link:
https://forums.autodesk.com/t5/powermill-forum/replace-a-character-in-file-with-a-macro/m-p/6774411#...
Rafael Sansão
Message 15 of 19
shirin.shah
in reply to: rafael.sansao
@rafael.sansao
Thanks for sharing the link, but I am just a beginner in Post processor editing, so it will be helpful if you can help me little more detail.
Let me explain you my exact requirement. We are using different OP number in our route card for any part, like, OP10-MILLING, OP20-TURNING, OP30-DEBURRING, OP40-INSPECTION, OP50-MILLING_RW, like that. So for all Milling OPs, I have a single PowerMill file and in that I have mentioned the OP_SEQ number and their number as highlighted in below image. Now I want to pull this information inside NC, so can you please provide solution for this?
It would be a great help. Thanks.
Message 16 of 19
rafael.sansao
Here's how to add the udp parameters:
Rafael Sansão
Message 17 of 19
shirin.shah
Thank you very much for the video, this is very helpful in deed.
I need little more than this. Is there any possibilities to set any condition with this.
At a time, we require only one output in the NC based on the operation. So can we put any condition to get either output from the list of OP SEQ?
Thanks in advance
Message 18 of 19
rafael.sansao
You need to provide more details/examples of how everything should work.
I advise you to create another topic.
Rafael Sansão
Message 19 of 19
shirin.shah
Thanks.
I found user defined setting output to be little complicated for us, so I have changed the requirement slightly.
The new topic is created for the same. Please refer below link for the same.
https://forums.autodesk.com/t5/powermill-forum/how-to-include-powermill-setup-name-inside-nc-program...
Thanks in advance.
