PowerMill Forum
Welcome to Autodesk’s PowerMill Forums. Share your knowledge, ask questions, and explore popular PowerMill topics.
How to separate Levels and Sets in a macro?
8 REPLIES 8
Message 1 of 9
iamcdn79
377 Views, 8 Replies
I have this working macro that arranges levels and sets in alphabetical order but it's not doing it the way I would expect.
I would like the levels in one alphabetical order and the sets in another alphabetical order below the levels but when running it arranges the levels and sets as one instead of separate
// Orders Model and Level names Alphabetically
ENTITY LIST models = sort(folder('model'), 'name')
ORDERSESSION model $models[0].name FIRST
int i = 0
FOREACH mod IN models {
	IF $i+1 < size(models) {
	    string previousModel = $models[i].name
		string currentModel = $models[i+1].name
		ORDERSESSION model $currentModel AFTER $previousModel
		$i = $i + 1
// Orders entities within each Level
ENTITY LIST levels = sort(folder('level'), 'name')
ORDERSESSION level $levels[0].name FIRST
int j = 0
FOREACH lev IN levels {
	IF $j+1 < size(levels) {
	    string previousLevel = $levels[j].name
		string currentLevel = $levels[j+1].name
		ORDERSESSION level $currentLevel AFTER $previousLevel
		$j = $j + 1
// Orders entities within each Set
ENTITY LIST sets = sort(folder('set'), 'name')
FOREACH set IN sets {
	ENTITY LIST setEntities = $set.entities
	setEntities = sort(setEntities, 'name')
	int k = 0
	FOREACH set IN setEntities {
		IF $k+1 < size(setEntities) {
		    string previousEntity = $setEntities[k].name
			string currentEntity = $setEntities[k+1].name
			ORDERSESSION set $currentEntity AFTER $previousEntity
			$k = $k + 1
Intel Core i9 13900KF CPU
128 GB Kingston Beast DDR4 SDRAM
PNY RTX A2000 6GB Video Card
WD 1 TB SSD Hard Drive
Windows 11 Pro
8 REPLIES 8
Message 2 of 9
icse
in reply to: iamcdn79
can you try this:
int i = 0
		$i = $i + 1
string list $levels = sort(extract(folder('level'),'Name'))
string list $sets = sort(extract(folder('set'),'Name'))
foreach $lvl in $levels {
	ordersession level ${lvl} last
foreach $set in $sets {
	ordersession set ${set} last
if its in the wrong order you can add the reverse function like this:
string list $levels = reverse(sort(extract(folder('level'),'Name')))
string list $sets = reverse(sort(extract(folder('set'),'Name')))
Message 3 of 9
iamcdn79
in reply to: icse
That didn't work as expected, I got the same result using both options
Windows 11 Pro
Message 4 of 9
icse
Thats strange...
How about to move the levels and sets into subfolders until we find a solution?
Message 5 of 9
iamcdn79
in reply to: icse
I can just move them manually for now
Windows 11 Pro
Message 6 of 9
icse
I cant test this atm but does this work?
string list $levels = sort(extract(filter(folder('level'),'this.Type == "level"'),'Name'))
string list $sets = sort(extract(filter(folder('level'),'this.Type == "set"'),'Name'))
	ordersession level ${set} last
shorter version but probably worse performance:
foreach $lvl in sort(extract(filter(folder('level'),'this.Type == "level"'),'Name')) {
foreach $set in sort(extract(filter(folder('level'),'this.Type == "set"'),'Name')) {
Message 7 of 9
iamcdn79
in reply to: icse
Both versions seem to work the same, haven't noticed a worse performance with the shorter version
Windows 11 Pro
Message 8 of 9
iamcdn79
in reply to: icse
When running this code Powermill organizes the model names instantly but levels and sets very slowly, is this a Powermill limitation? Or is there something else in the code that can speed up the levels and sets?
//Orders Model and Level names Alphabetically
int i = 0
	    string previousLevel = $models[i].name
		string currentLevel = $models[i+1].name
		ORDERSESSION model $currentLevel AFTER $previousLevel
		$i = $i + 1
// Extract level names and sort them
// Extract set names without sorting
STRING LIST $sets = extract(filter(folder('level'),'this.Type == "set"'),'Name')
// Order the sets
this was the same speed
Windows 11 Pro
Message 9 of 9
icse
Yes it seems like moving entities in Powermill is very time consuming.
You could write some more fancy algorithm that only moves necessary items.
Mine just moves every item once even if its in right place.
Technology Administrators
