PowerMill Forum
Welcome to Autodesk’s PowerMill Forums. Share your knowledge, ask questions, and explore popular PowerMill topics.
How to read registry key
8 REPLIES 8
Message 1 of 9
555 Views, 8 Replies
For a PowerMill macro, how does one go about reading a registry key string value?  I found REG EXPORT and REG QUERY commands but am not sure how to use them.  I tried them in a macro and they failed  (PowerMill 2021 Ultimate).
Labels (2)
8 REPLIES 8
Message 2 of 9
TK.421
I dont see that in the Parameter Reference doc anywhere. where did you find those?
the numbers never lie
Message 3 of 9
in reply to: TK.421
I found REG EXPORT here: Link
I found REG QUERY but now that I look at it again, I may have mistaken it for Powershell.  Either way, is it possible to query the registry?
Message 4 of 9
TK.421
I'm not a super expert in this area. you could most likely do it from a batch file as was suggested in the original reply, or you could certainly do it via a plugin. What are you wanting to do?
Message 5 of 9
I'm processing some SolidWorks part files and the output of that process is the input to PowerMill.  I have a set of 10 macros that run individually, and some macros use data that comes from SolidWorks.  I write data to various text files that the powermill macros read from but only if they know the location.  I need a static, readable location that the powermill macro can look at to find where those text files are located.  I was going to use the registry since that can be set with my program.
Message 6 of 9
kukelyk
Hi, from a macro You can call a vbs to run
<macrocode>
OLE FILEACTION 'open' Your.vbs
</macrocode>
<vbscode>
console_exe= CREATEOBJECT("Wscript.Shell").RegRead("HKEY_LOCAL_MACHINE\SOFTWARE\Delcam\Postprocessor\" & CurrentVersion & "\ExecutablePath")
</vbscode>
Message 7 of 9
TK.421
in reply to: kukelyk
Welcome back @kukelyk ! Are you going to be a regular on the forum again?
Message 8 of 9
Thank you for your response.  How do I go about assigning the value of the registry key to a macro variable?
Message 9 of 9
Any update on the ability to read the registry?  Thanks
Technology Administrators
