PowerMill Forum
Welcome to Autodesk’s PowerMill Forums. Share your knowledge, ask questions, and explore popular PowerMill topics.
How to never miss tool data cut
7 REPLIES 7
Message 1 of 8
nubrandao
382 Views, 7 Replies
Hi, don't know if more people have this problem
But sometimes I miss to check speed and feeds of the toolpath, is always a problem, because they are pressing us to be more perfect and reduce times.
So, what can I do to never miss, I don't want to check all the time.
We have 6 database, almost 600 tool per data base
How to make toolpath read the tool data according what is set?
What fields data cut should be ? Getting all data in all tools is going to be hard.
Any macro?
7 REPLIES 7
Message 2 of 8
icse
in reply to: nubrandao
at the end you could run a macro wich checks if the feed  matches the tool data.
Now you could automatically load the data from the tool if its incorrect.
Or display the toolpaths with wrong cutting data.
I personally like the second one more since somethimes i like to adjust them a lil bit here and there.
you also could add a tolerance to the feed like +-20% is ok etc.
I can write you such a macro if you can tell me how exactly you store your cutting data.
Message 3 of 8
nubrandao
in reply to: icse
I like more the idea, to run a macro to update all feed and tools I selected.
All the tools I load a from a tool database, one by one.
I all I need is the macro to go toolpath and click that but that update feed and speed.
Although, I have to loose some time checking all feed and speed from each tool
Message 4 of 8
icse
just select the toolpaths you whant to update the feed in the explorer:
foreach $tp in filter(explorer_selected_entities(),'this.RootType == "toolpath"') {
	activate toolpath ${tp.Name}
	EDIT DATAFROMTOOL ;
	RESET TOOLPATH FEEDRATE
Message 5 of 8
rafael.sansao
Hello Nuno,
You can do this using OptiNC. Just select the tools you want and click the update button.
Rafael Sansão
Message 6 of 8
icse
heres an alternative macro, it does the same but you can also select the tools you whant to update then the macro looks for the toolpaths that uses the tools you selected and updates:
entity list $selection = explorer_selected_entities()
if size($selection) > 0 and $selection[0].RootType == 'toolpath' {
	foreach $tp in $selection {
		EDIT DATAFROMTOOL ;
} elseif size($selection) > 0 and $selection[0].RootType == 'tool' {
	foreach $t in $selection {
		foreach $tp in filter(folder('toolpath'),'this.Tool.Name == "' + $t.Name + '"') {
			EDIT DATAFROMTOOL ;
Message 7 of 8
How much is OptiNC to buy/license?
Their website extols it's virtues but can't find any info on cost.
Message 8 of 8
nubrandao
in reply to: rafael.sansao
Perfect, I tested and work
