PowerMill Forum
Welcome to Autodesk’s PowerMill Forums. Share your knowledge, ask questions, and explore popular PowerMill topics.
How to get position of hole when have multiple workplane?
3 REPLIES 3
Timothy2021
631 Views, 3 Replies
Hello, I have an issue with macro, I try to get the position of hole through WPPoint, but if there are multiple workplane, the position is incorrect.
Version: 2021.1.1.2021109
Test Macro:
ENTITY fs=entity('featureset','')
FOREACH item IN components($fs) {
print par $item.WPPoint
Steps to reproduce:
  1. Import model(this model just have one hole)
  2. Create and active workplane “A”
  3. Copy workplane “A” to “B”, move “B” to somewhere
  4. Active workplane “B”
  5. Create and active featureset
  6. Create holes from model, use active workplane only
  7. Run macro, WPPoint and values of position in the Edit Hole dialog are different. WPPoint relative to workplane A, position in the Edit Hole dialog relative to workplane B.
Please help me to get the correct hole position, thanks!
Labels (1)
3 REPLIES 3
cfastNJWK6
in reply to: Timothy2021
I'm sure that there is a better way to do this, but this is the first that popped into my head.  You can calculate a block around each individual hole and then look at the block size:
EDIT BLOCK COORDINATE WORKPLANE
EDIT BLOCK LIMITTYPE FEATURESET
EDIT BLOCKTYPE BOX
FOREACH $item IN components($fs) {
EDIT FEATURESET $fs SELECT $item
EDIT BLOCK RESET
EDIT BLOCK XLEN "0"
EDIT BLOCK YLEN "0"
print par $Block.Limits.Xmax
print par $Block.Limits.Ymax
print par $Block.Limits.Zmax
EDIT FEATURESET $fs DESELECT ALL
Timothy2021
in reply to: cfastNJWK6
Thank you for replying, I'll give it a try.
Timothy2021
Perfect, Thank you so much.
Technology Administrators
