How to drill in steps
adolfosiYYC5A
adolfosiYYC5A
Community Visitor
Community Visitor
I really need to make some holes (about 52 holes) on the powermill in 2 steps...   and neds to turn 3 times.. on de same hole diameter...
i´m using the perfil.. and spiral.. but .. i cant make 2 times.. for example in -18  to -19 spiral .... and -40 to -41 with...
i´ve done 2  strategies.. than..  it goes out the hole finishing the 52 holes than come back to make the end of it...
is there any way to make the holes...  once each hole... 2 diferent deep and making 3 turns on that deep???
kamalrajcv
Yes, it is possible to create a toolpath that can drill the holes in two steps with 3 turns at each depth. Here's how you can do it in PowerMill:
Step 1: Create a Drill Operation
  • Create a new drill operation by selecting the "Drill" option from the "New" drop-down menu.
  • Select the tool you want to use for drilling and set the drill parameters such as the diameter, cutting parameters, and drilling depth.
Step 2: Set Up the Hole Pattern
  • In the "Hole" tab, select the "Pattern" option and set up the pattern for the 52 holes you need to drill. You can choose from a variety of patterns such as linear, circular, rectangular, etc.
  • In the "Depth" tab, set the drilling depth for the first step. For example, if you want to drill the holes to a depth of 10mm, set the depth to 5mm for the first step.
Step 3: Create the First Drill Path
  • In the "Path" tab, select "Spiral" as the path type and set the spiral parameters such as the starting point, the spiral direction, and the pitch.
  • Set the start and end depths to the first drilling depth you want to achieve (e.g., 0mm to 5mm).
  • Select "OK" to create the first drill path.
Step 4: Create the Second Drill Path
  • Repeat steps 2 and 3 to create a second drill path with the same hole pattern but with the drilling depth set to the second step (e.g., 5mm to 10mm).
  • Make sure to adjust the spiral starting point so that it starts at the bottom of the hole you drilled in the first step.
Step 5: Verify and Simulate the Toolpath
  • Once you have created both drill paths, verify and simulate the toolpath to make sure that the tool will drill the holes as expected.
  • If necessary, adjust the toolpath parameters such as the feed rate, spindle speed, and cutting parameters to optimize the drilling process.
By following these steps, you can create a toolpath that drills the 52 holes in two steps with 3 turns at each depth.
