PowerMill Forum
Welcome to Autodesk’s PowerMill Forums. Share your knowledge, ask questions, and explore popular PowerMill topics.
How to change language in Powermill
6 REPLIES 6
iortiz
4157 Views, 6 Replies
Could be possible to change the Powermill's language from the default install to another language?
For example from English (default install) to Russian
Regards.
6 REPLIES 6
Yogesh.Mohite
in reply to: iortiz
Hi @iortiz,
In PowerMill Echo Command you need to type LANG RUSSIAN.
Hope this helps.
Thank You
Yogesh Mohite
iortiz
in reply to: Yogesh.Mohite
Were is located Powermill Echo command?
Thanks.
Regards.
iamcdn79
in reply to: iortiz
If you click on Tools it will be the very first option. When you turn it on a dialog box at the bottom of the powermill screen will open up where you would type your command
Intel Core i9 13900KF CPU
128 GB Kingston Beast DDR4 SDRAM
PNY RTX A2000 6GB Video Card
WD 1 TB SSD Hard Drive
Windows 11 Pro
tejas.lawate
in reply to: iortiz
How to change it to Chinese language?
lang Chinese-TWN or Chinese-CHN i think
but when we change the language it jumps back to the original language when we close pm how can it be change for ever.
BTCouto
in reply to: gosmann.andreas
Hi Gosmann
to change by default, you need to go to the control panel - region - and set the format for the country / Language you want.
Hope this helps.
Best regards,
Bruno Couto
Tech Support Engineer
NORCAM
