Could be possible to change the Powermill's language from the default install to another language?
For example from English (default install) to Russian
Solved by iamcdn79. Go to Solution.
Solved by Yogesh.Mohite. Go to Solution.
If you click on Tools it will be the very first option. When you turn it on a dialog box at the bottom of the powermill screen will open up where you would type your command
lang Chinese-TWN or Chinese-CHN i think
but when we change the language it jumps back to the original language when we close pm how can it be change for ever.
