hole feature set to get xyz dia and height
malinsAM3TM
malinsAM3TM
HI !
can this be modify to get additional two columns for featureset height and diameter.
yd_kwon
Try This.
There is no need to set up blocks to find points.
If you are curious, check it with macro debug
ENTITY $fset = INPUT ENTITY FEATURESET "Select the Featureset to output positions from"
string $txtCheck = ""
FOREACH $feat IN components($fset) {
	EDIT FEATURESET $fset DESELECT ALL
      IF feat.type == 'hole' {
		EDIT FEATURESET $fset SELECT $feat
		//txt Initialize
		$txtCheck = ""
		//Hole Center Point
		$txtCheck = $txtCheck + "Point X" +$feat.Point[0] + " "
		$txtCheck = $txtCheck + "Y" +$feat.Point[1] + " "
		$txtCheck = $txtCheck + "Z" +$feat.Point[2] + crlf
		//Hole feature
		$txtCheck = $txtCheck + "Dia" +$feat.Diameter + " "
		$txtCheck = $txtCheck + "Depth" + $feat.Depth + " "
		$txtCheck = $txtCheck + "Bottom" + $feat.Bottom + " "
		$txtCheck = $txtCheck + "Draft" + $feat.Draft + crlf
		//Text check
		Message info $txtCheck
CAM-Fusion 360/Inventor
CAD-Fusion 360/Inventor
Before PowerMILL
malinsAM3TM
Sir Thanks for reply
The macro which u sent is showing mesage is on screen which is not solving our purpose.
Sir I need out put in excel file as below
1. X LOCATION
2. Y LOCATION
3. START Z
4. END Z
5. TOTAL HEIGHT
AND
6. DIAMETER
Sir
the attched macro is  giving output for 4 points
need to add totla height and diamater in same macro
please refer attached file for referance
Thank you
yd_kwon
I didn't give all the answers.
However, it is possible enough if you modify your macro based on the code I posted.
Before PowerMILL
