PowerMill Forum
Welcome to Autodesk’s PowerMill Forums. Share your knowledge, ask questions, and explore popular PowerMill topics.
Help with this macro
10 REPLIES 10
Message 1 of 11
abner_asafe
495 Views, 10 Replies
Hello, I need help with this macro, at the beginning I need it to show a list with the workplanes to select just one (commented part of the code) after that open the option to create a plane aligned in the geometry and then get the plane that I selected at the beginning and align its top view with the plane aligned in the geometry
//   STRING LIST $PlanoP = {}
//   $PlanoP = INPUT ENTITY MULTIPLE Workplane "Selecione o plano de trabalho principal"
//   GRAPHICS LOCK
//   DIALOGS MESSAGE OFF
//  DIALOGS ERROR OFF
 ACTIVATE Workplane INCLINADO
MODE WORKPLANE_CREATE ; INTERACTIVE GEOMETRY
   Macro Pause "Clique na face que deseja alinhar a vista"
ACTIVATE Workplane "1"
ROTATE TRANSFORM TOP
COPY WORKPLANE INCLINADO
RENAME Workplane "INCLINADO_1" "INCLINADO_X"
MODE WORKPLANE_EDIT START "INCLINADO_X"
MODE WORKPLANE_EDIT ALIGN VIEW
MODE WORKPLANE_EDIT FINISH ACCEPT
delete workplane"1"
10 REPLIES 10
Message 2 of 11
icse
in reply to: abner_asafe
you need a entity list insted of a string list:
entity LIST $PlanoP = {}
and for a single workplane use this:
entity $PlanoP = INPUT ENTITY Workplane "Selecione o plano de trabalho principal"
Message 3 of 11
abner_asafe
   GRAPHICS LOCK
   DIALOGS MESSAGE OFF
  DIALOGS ERROR OFF
 string $planoN= $PlanoP
 ACTIVATE Workplane $PlanoP
COPY WORKPLANE $PlanoP
RENAME Workplane "$PlanoN" "INCLINADO_X"
delete workplane"1"
is this corret?
Message 4 of 11
icse
So you whant to change the rotation of the selected workplane with the rotation of the workplane the user created?
Message 5 of 11
abner_asafe
in reply to: icse
Yes exactly that
Message 6 of 11
icse
Try this:
string $temp = new_entity_name('workplane','')
MODE WORKPLANE_CREATE ${temp} INTERACTIVE GEOMETRY
ACTIVATE Workplane ${temp}
entity $t = entity('workplane',$temp)
bool $sucsess = set_workplane($PlanoP, entity('workplane',$temp).YAxis,entity('workplane',$temp).ZAxis, $PlanoP.Origin )
ACTIVATE Workplane ${PlanoP.Name}
purge workplane ${temp} yes
Message 7 of 11
abner_asafe
works almost perfect i just need to create a copy of the initial selected workplane and aling this copy
Message 8 of 11
icse
im not able to test this atm but try this:
string $PlanoN = 'INCLINADO_X'
if entity_exists('workplane',$PlanoN) {
	$PlanoN = new_entity_name('workplane',$PlanoN)
create workplane $PlanoN
bool $sucsess = set_workplane($PlanoN, entity('workplane',$temp).YAxis,entity('workplane',$temp).ZAxis, $PlanoN.Origin )
ACTIVATE Workplane ${PlanoN.Name}
Message 9 of 11
abner_asafe
it's giving an error in the "bool $sucess" function line
Message 10 of 11
icse
bool $s = 0
$s = set_workplane(entity('workplane',$PlanoN),$PlanoP)
$s = set_workplane(entity('workplane',$PlanoN), entity('workplane',$temp).YAxis,entity('workplane',$temp).ZAxis, entity('workplane',$PlanoN).Origin )
ACTIVATE Workplane ${PlanoN}
Message 11 of 11
abner_asafe
Perfect thank you
