Help with IF Statement
Beta_Librae
Beta_Librae
Salutations All,
Thought this one was gonna be easy for me, I was wrong.
Would greatly appreciate if anyone would tell me what's wrong with this code?
IF $Pattern == "CLAMP POCKET" {
RENAME Pattern "CLAMP POCKET" "CLAMP POCKET_1"
Kind Regards,
Not cnc, you can call me Peabrain
gosmann.andreas
STRING $CP = "CLAMP POCKET"
 IF ENTITY_EXISTS('pattern', CP) {
 RENAME Pattern $CP "CLAMP POCKET_1"
Beta_Librae
Thank you kindly, much appreciated.
I'm guessing that I can follow the same format for a toolpath?
Kind Regards,
rafael.sansao
You can also use the new_entity_name() command.
With this approach you will never get an error when running the macro.
IF ENTITY_EXISTS("Pattern", $CP) {
	RENAME Pattern $CP ${new_entity_name("Pattern", $CP)}
STRING $TP = "TOOLPATH NAME"
IF ENTITY_EXISTS("Toolpath", $TP) {
	RENAME Toolpath $TP ${new_entity_name("Toolpath", $TP)}
Rafael Sansão
OptiNC - www.optinc.tech
Beta_Librae
Thanks Rafael,
Really appreciate your input. Always glad to know more ways than one.
Kind Regards,
dan_mickle
Does new_entity_name capture the name of the newly created entity automatically? How does it work?
rafael.sansao
Rafael Sansão
