HELP MACRO
HELP MACRO
XsR_L
HELP MACRO
XsR_L
Hello everyone, have a nice day,
I have a problem to solve,
Change toolpath segment start and end values
I tried many ways but couldn't solve it so please help me solve this problem
Thanks in advance..
Take care and have a nice day!
int c=toolpath_component_count(toolpath, 'segments')
FORM TPLIST
int RR=$C
STRING LIST TPList=extract(folder('toolpath'),'name')
STRING ActiTH=basename(pathname('Toolpath',name))
Bool swapped = 1
INT Idx=0
INT i1=SIZE(TPList)
IF ActiTH!="" {
WHILE i1>0 AND swapped {
$swapped=0
IF TPList[Idx]==ActiTH {
$swapped=0
$Idx=Idx+1
IF Idx==i1 {
ACTIVATE TOOLPATH $TPList[0]
} ELSE {
ACTIVATE TOOLPATH $TPList[Idx]
} ELSE {
$swapped=1
$Idx=Idx+1
} ELSE {
FORM TPLIST
EDIT TPSELECT ; TPLIST UPDATE
0 NEW
int i=1
while i<RR {
$i TOGGLE
$i=i+1
TPLIST ACCEPT
DIALOGS MESSAGE ON
DIALOGS ERROR ON
Version 2016
icse
I dont get it,
how do you whant the toolpath to be reordered?
XsR_L
Select the tool path in advance as a reference
icse
i still dont get it...
Do you try to invert the current selection?
Wich toolpaths you want to select?
can you add some screenshots(before/after)
icse
Does this work for you?
entity $tpA = input entity toolpath 'Select Toolpath A'
if $tpA.Computed == 0 {
	return
entity $tpB = input entity toolpath 'Select Toolpath B'
if $tpB.Computed == 0 {
	return
activate toolpath ${tpA.Name}
FORM TPLIST
int $segmentIndex = segments($tpA)
string list $startAndEndPoint = {}
while $segmentIndex > 0 {
	$segmentIndex = $segmentIndex - 1
	int $i = add_last($startAndEndPoint, list_cell_value('TPList.TPListView', $segmentIndex, 1)+list_cell_value('TPList.TPListView', $segmentIndex, 2))
activate toolpath ${tpB.Name}
$segmentIndex = segments($tpB)
	if member($startAndEndPoint,list_cell_value('TPList.TPListView', $segmentIndex, 1)+list_cell_value('TPList.TPListView', $segmentIndex, 2)) {
		EDIT TPSELECT ; TPLIST UPDATE\r ${segmentIndex} TOGGLE
