HEIDENHAIN TNC530 5-AXIS POST-PRCESSOR
kmarkopouliotis
kmarkopouliotis
I'm trying to build a 5-axis Post-Processor [B & C]. Can somebody give me a Post-Processor in order to use it as guide...????
Thank you.
boopathi.sivakumar
Hi @kmarkopouliotis
The Configuration should be something like this in onOpen section
  } else if (true) {
    // NOTE: setup your machine here
    //var aAxis = createAxis({coordinate:0, table:true, axis:[1, 0, 0], range:[-120.0001, 120.0001], preference: properties.preferTilt});
    var bAxis = createAxis({coordinate:1, table:true, axis:[0, 1, 0], range:[-120.0001, 120.0001], preference:1});
    var cAxis = createAxis({coordinate:2, table:true, axis:[0, 0, 1], range:[0, 360], cyclic:true});
    machineConfiguration = new MachineConfiguration(bAxis, cAxis);
    setMachineConfiguration(machineConfiguration);
    optimizeMachineAngles2(0); // using M128 mode
You can get details more on this thread
How to set up a 4/5 axis machine configuration
Boopathi Sivakumar
Senior Technology Consultant
kmarkopouliotis
I'm using Powermill and I'm trying to build Post Processor with Autodesk Post Processor Utility.
boopathi.sivakumar
@kmarkopouliotis
Apologize!! its comes at the wrong place..
Probably you should contact our reseller for the post processor service
https://servicesmarketplace.autodesk.com/providers?search=&search_within=powermill&ci=All&sort_by=se...
Boopathi Sivakumar
