Getting hold of a trial version
planetzargon
planetzargon
I have no idea what the situation is elsewhere, but here in the UK it's appears as if Autodesk have no interest in selling Powermill. I phoned the number on the UK Powermill page who helpfully told me they don't deal with Powermill, that was some other department, to which I was given some phone numbers to call. They were incorrect numbers. I filled out the online form several times. I tried calling the official resellers. So far I have nada. All I'm after is a trial.
I'm evaluating Sprutcam and found it very klunky. Having used Fusion 360 for the past five years or so (maybe longer? I forget) I'm hoping Powermill will be a better experience. I need the robot plugin from Powermill because in this case I want to program a Kuka 150.
So, is there some secret to getting a Powermill trial, or is this a mythical beast? Is this just a UK issue, or is this endemic and just what I should expect? Is there a magical incantation someone can point me to?
Jonathan_Artiss19
HI @planetzargon
I did a quick search for providers in the UK and surrounding area, hope this helps.
Results here
I would recommend using Autodesk Ava to get yourself a trial version.  You'll need to create an Autodesk account and sign into it before you request the trial.
Jonathan Artiss
Senior Applications Engineer | DSI
Autodesk Expert Elite member
DSI, Design and Software International Autodesk Gold Partner
craig.shipley
Autodesk Support
Autodesk Support
Hi @Jonathan_Artiss19 hope you're well
Not sure if it's just me but that link doesn't work unfortunately.
I agree though, AVA is the best bet when using the online tools.
Jonathan_Artiss19
In this case, it will be a bit more work on your end to use the filters but the Service Marketplace is where I was trying to link too.
Try to find a local PowerMill reseller in your area using the link below.
https://servicesmarketplace.autodesk.com/
Jonathan Artiss
CGBenner
@planetzargon  @Jonathan_Artiss19  @craig.shipley
Does this work?
Chris Benner
Benjamin.Br
Hello @planetzargon. I'm sorry you're having a frustrating experience getting a trial of PowerMill. Our technical sales manager in the UK, Robin Smith, should be able to sort you out with a free trial. Contact him directly either by DMing @robinsmith888 or emailing [email protected].
Benjamin Brereton
Director, Engineering
planetzargon
Thanks to all of you. In the end I downloaded Powermill and of course it went straight into trial mode. I was led to believe from the Autodesk website and their support staff you have to apply for a trial. Clearly there is a huge disconnect here. Hallo, Autodesk?
