Feature set active expression
jsweatherbie
jsweatherbie
Hello ive been trying to figure out what the expressions are for things that are active so i can display it in my custom tab but i cant seem to find any information on it regarding it. if theres a help for it or something that would be appreciated but mainly im looking for a expression for active feature set.
another thing can you make the expression like the  "toolpath" tab where its a drop down and you can change the active tool and featureset in "hole feature set"
LasseFred
I do not know if I have understood your question properly. but you can use these strings to get the names:
$tool.name
$toolpath.name
$boundary.name
or:
See at page 98 in the macro programming guide:
https://knowledge.autodesk.com/sites/default/files/file_downloads/PM_Macro_Programming_Guide.pdf
Evaluate the active expression
For example, the Boundary.Tool parameter is not active for a block
or sketch type boundaries. You can test whether a parameter is
active or not with the inbuilt active() function. This can be useful in
calculations and decision making.
The basic control structure is:
IF active(….) {
______________________
Lasse F.
jsweatherbie
If you look at the default tabs under “feature set” it’ll show you the active featureset. I’m trying to get the active featureset expression into another tab I created. I’ve been looking through the help and everything and I can’t seem to find anything to help me besides the expression editor but that’s no good for my use cause it won’t show the expression….
I’ve tried $toolpath.featureset.name it worked for a second then once I switched to another feature it errored out.
Sean570
$entity('featureset','').name
