PowerMill Forum
Welcome to Autodesk’s PowerMill Forums. Share your knowledge, ask questions, and explore popular PowerMill topics.
Feature set active expression
3 REPLIES 3
jsweatherbie
289 Views, 3 Replies
Hello ive been trying to figure out what the expressions are for things that are active so i can display it in my custom tab but i cant seem to find any information on it regarding it. if theres a help for it or something that would be appreciated but mainly im looking for a expression for active feature set.
another thing can you make the expression like the  "toolpath" tab where its a drop down and you can change the active tool and featureset in "hole feature set"
Tags (1)
Labels (3)
3 REPLIES 3
LasseFred
in reply to: jsweatherbie
I do not know if I have understood your question properly. but you can use these strings to get the names:
$tool.name
$toolpath.name
$boundary.name
or:
See at page 98 in the macro programming guide:
https://knowledge.autodesk.com/sites/default/files/file_downloads/PM_Macro_Programming_Guide.pdf
Evaluate the active expression
For example, the Boundary.Tool parameter is not active for a block
or sketch type boundaries. You can test whether a parameter is
active or not with the inbuilt active() function. This can be useful in
calculations and decision making.
The basic control structure is:
IF active(….) {
______________________
Lasse F.
jsweatherbie
in reply to: LasseFred
If you look at the default tabs under “feature set” it’ll show you the active featureset. I’m trying to get the active featureset expression into another tab I created. I’ve been looking through the help and everything and I can’t seem to find anything to help me besides the expression editor but that’s no good for my use cause it won’t show the expression….
I’ve tried $toolpath.featureset.name it worked for a second then once I switched to another feature it errored out.
Sean570
$entity('featureset','').name
Technology Administrators
