Fastest way to program 3d chamfer with tip radiused tool?
johnc4668
johnc4668
pm Newbie asking for advice to get a good toolpath strategy to machine these pin cbore inside chamfers. We typically used tip radiused tools for this as sizes vary. Currently im using constant z but is there anything else i could use to make this faster?
ChristopherMarion
@johnc4668
Using a tool other than a chamfer mill can be done in a drilling strategy.  Look at the attached example.  I showed you two different options here.
  1. Profile - Individual Z levels
  2. Helical - 1 constant toolpath segment
Hope this helps!
Christopher Marion
Technical Specialist - CAM
SolidCAD - Canada
TK.421
you can do it with a spot drill when you spot drill your holes, that's what i do. you just need to know the angle of your spot drill. I use a 120° included angle spot drill, so that's what i'll use in this example:
Say I have a 3/8" hole and I want a .02" chamfer on it, that makes the OD of the chamfer .395".  Now you just do a little trig to figure out what depth to program: radius of chamfer/tan(point angle) = depth of hole. so using my spot drill and 3/8 hole, the equation would look like this:
.1975/tan(60) = .114
that's the depth I program on my spot drill for all 3/8 holes. maybe i'll add a quarter second of dwell time if I remember.
now, it is a bit of work on the front end with programming but not too bad, and it takes a heck of a lot less time at the machine.
This can work with any spot/center drill provided you know the angle of it, and since you're a competent machinist, you do! I've even taken center drills and ground the tip off to chamfer holes in a secondary operation, but I try to do it in the first operation whenever I can.
Hope this helps! Should save you loads of time and give you nice, uniform, chamfers with the tools you already are using anyway.
the numbers never lie
Meysam_Ghorbani
use the chamfer milling in curve machining
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
