Hello, my problem concerns the forward speeds, in detail I would like macros to be applied to the speeds as in example. I tried to fix it by myself, but it doesn't work.
Can anyone help me?
Solved by cfastNJWK6. Go to Solution.
Had to add some user parameters and a script, but I think this is what you are looking for.
hi@cfastNJWK6
I test files
There is no output variable at the beginning of the program. What is the reason for this?
The same logic needs to be applied to the Circular and Helical moves in the "Arc" portion of the post.
It looks like you have different feedrate logic setup for drilling. Try posting without using drilling cycles, or update the drilling feedrate logic to match.
hi dear experts please help me i need fanuc om turnning or lathe post processor please give me post processor
