failures, errors in version 2019
rob_carri
rob_carri
good has all. with this beginning of the year we have started to work with the 2019 version, and I have seen that we are still dragging past mistakes that have not yet been solved
if we try to work with the limit of the trajectory, limiting by polygon ... if you work with the views of the cube, you do not see the line of limitation
2.JPGin the milling of a cashier both roughing and finishing, if you exceed the size of the tool edge, powermill does not understand that this recessed and gives you collision
this image shows the same tool as the previous one but saying that all of it is cut, I have removed the destalone that carries the tool and so it does not fail ... it is a mistake that we have been dragging for years
and not to mention the bits, they always collide if they do not have all the edge in the whole length of the bit
in this version and after so much had cost, now it does not work again to be able to change the entrances or exits of the trajectory selecting the one that you want with the mouse, changes them all
We really can not establish a fixed point on the screen with the mouse and from there do the rotation, so much?
I hope you get interested in repairs
thank you
LasseFred
I have the same problem.
Another error is also there are problems with Default Surface Thickness when you use drilling methods.
it will not ignore surfaces.
______________________
Lasse F.
andrew.t.woodZF7L7
Re: Point 3.
I believe that you're selecting a toolpath segment via the Toolpath re-order form or else a mouse click, and then editing the leads expecting only the leads for that particular section to change? However, I'm not sure that PowerMill has ever worked like this? (could you possibly state a version of PowerMill where it did work this way?)  Anyway, if you mouse-select say a series of orange lead-in arcs rather than the toolpath segment itself, and then edit the radius value of said arcs, PowerMill does only update the selected leads. As far as I'm aware, selective lead editing works by selecting the leads that you want to edit, and not the toolpath segment that they're associated with.
Benjamin.Br
1. This is a known issue that happens when using a flat background colour. It is on our list to fix but is considered to be fairly low priority. In the meantime it can be worked around by changing the background colour settings to graded colours.
4. This should be addressed by an enhancement we are currently working on.
Benjamin Brereton
Director, Engineering
rob_carri
@Benjamin.Br
OK PERFECT THANK YOU
Have you noticed that in the levels, when you turn off and turn on the bulbs, the level is stuck to the mouse and you are always raising and lowering it to reorder it?
Benjamin.Br
Yes, we are aware of that problem. It is also on our list to fix but is also considered to be fairly low priority.
Benjamin Brereton
