PowerMill Forum
Welcome to Autodesk’s PowerMill Forums. Share your knowledge, ask questions, and explore popular PowerMill topics.
extract toolpath folder in project folder
5 REPLIES 5
karan30782
564 Views, 5 Replies
HI, There !
I'm exploring through a macro that must create folders in "Nc programs" explorer.
Folders are already in "Toolpath" explorer.
And these "Nc programs" folder must be created in Project > Ncprograms.
I'm working on this code below ...........
// macro start ===========
STRING $dirpath = project_pathname(0) + "/ncprograms/"
MKDIR $dirpath
EXPLORER SELECT TOOLPATH ROOT
STRING LIST TPFOLDERS = get_folders('TOOLPATH')
FOREACH tp IN TPFOLDERS {
CREATE FOLDER project_pathname(0) + '\ncprograms\' $tp
can someone add their idea, where I'm wrong.
Thank you !
5 REPLIES 5
TRY THESE MACROS. HOPE WILL HELP.
THANK YOU.
Thanks for replying,
With your code It extract folders from "toolpath" to "nc program".
That's fabulous.
But, even after so many attempt I'm unable to create those folder in project > ncprogram (folder)
Thanks again !
you have to save your project and run the "02_folder_matching.mac". Afterward when you write your NCPROGRAM it will be written in the same position (tree) in ncprogram file.
Hi ! @kmarkopouliotis
I just followed th steps and it worked somewhat.
I still didn't got final solution and yet working on it.
But, anyway your code helped me alot.
Thank you !
kl1445
in reply to: karan30782
Hi
I had the same problem before, but I have solved it, I hope you can use it
STRING $dirpath = project_pathname(0) +"/ncprogram"+"/"
MKDIR $dirpath
STRING $path = project_pathname(0) + "/ncprogram"
MKDIR $path
EDIT NCPROGRAM ALL FOLDER PROJSELECTOR $path
NCGLOBAL APPLY
NCGLOBAL ACCEPT
