Exporting set of tools as.ptf
anto_joseph4HH2K
anto_joseph4HH2K
Hi ,
Can anyone advise me on how to export a set of tools used in a project as .ptf so i can call in these tools later in different projects.?
iamcdn79
Make sure to just have your tools in the project, if you have workplanes, boundaries it might save that. When saving, save as .ptf
When importing
Intel Core i9 13900KF CPU
128 GB Kingston Beast DDR4 SDRAM
PNY RTX A2000 6GB Video Card
WD 1 TB SSD Hard Drive
Windows 11 Pro
TK.421
Here's the macro I use, you'll just have to change the file paths.
To Export (make sure project is saved):
FUNCTION MAIN() {
    STRING $template_name = INPUT "Save Tool Template As..."
    STRING $template_path = "S:/Software/PowerMill/Templates/Tool Templates/" + $template_name
    IF $length(project_pathname(0)) == 0 {
        MESSAGE WARN 'Save project first.'
        MACRO ABORT ALL
    IF $SIZE(folder('tool')) == 0 {
        MESSAGE WARN 'No tools in project.'
        MACRO ABORT ALL
    PROJECT SAVE
    IF dir_exists($template_path) {
        DELETE DIRECTORY $template_path
    MKDIR $template_path
    STRING $pmlprj_content = ""
    FOREACH t IN folder('Tool') {
    // FOREACH t IN folder('Workplane') {
        STRING $tool_name = "x" + $t.ID + ".pmlent"
        STRING $tool_full = project_pathname(0) + "/" + $tool_name
        STRING $dest_path_full = $template_path + "/" + $tool_name
        COPY FILE $tool_full $dest_path_full
        $pmlprj_content = $pmlprj_content + $tool_name + " pmlEntTool '" + $t.Name + "'" + CRLF
        // $pmlprj_content = $pmlprj_content + $tool_name + " pmlEntWorkplane '" + $t.Name + "'" + CRLF
    STRING $proj_name = "/" + project_pathname(1) + ".pmlprj"
    STRING $path_full = project_pathname(0) + $proj_name
    FILE OPEN $path_full FOR READ AS input
    STRING L1 = ""
    STRING L2 = ""
    STRING L3 = ""
    FILE READ $L1 FROM input
    FILE READ $L2 FROM input
    FILE READ $L3 FROM input
    FILE CLOSE input
    $L1 = $SIZE(folder('tool')) + substring($L1, position($L1, " ", 0), length($L1))
    // $L1 = $SIZE(folder('workplane')) + substring($L1, position($L1, " ", 0), length($L1))
    STRING $dest_path_full = $template_path + $proj_name
    FILE OPEN $dest_path_full FOR WRITE AS output
    FILE WRITE $L1 TO "output"
    FILE WRITE $L2 TO "output"
    FILE WRITE $L3 TO "output"
    FILE WRITE $pmlprj_content TO "output"
    FILE CLOSE output
    MESSAGE INFO "Tool objects saved successfully."
To Import:
FUNCTION MAIN() {
    // Create a list of ptf files including the full folder path.
    STRING LIST $ptf_files = list_files('dirs', 'S:\Software\PowerMill\Templates\Tool Templates')
    // Create a new list "$Template_Names" without the pathname included. Only the filename.
    STRING LIST $Template_Names = {}
    FOREACH $File IN $ptf_files {
        INT $Ok = add_last($Template_Names, TOKENS($File, "/")[SIZE(TOKENS($File, "/"))-1])
    // Display only the "$Template_Names" in your pulldown list
    INT LIST $C = INPUT CHOICE MULTIPLE $Template_Names "Select File"
    // Import file(s) from the original list which includes the full pathname
    foreach file IN C {
        PROJECT IMPORT ${$ptf_files[$file]}
Put these on a button on your custom ribbon tab.
the numbers never lie
