I need to export a file, an .STL model, relative the the workplane used in my NC program. Is this possible?
Solved by john_lute. Go to Solution.
For that, I am using the model transformations - "Transform to World" and "Transform to Workplane".
Having activated a particular workplane, transform an STL model to the world, export an STL model, transform back to workplane.
https://knowledge.autodesk.com/support/powermill/learn-explore/caas/CloudHelp/cloudhelp/2022/ENU/PWR...
I have been using Powermill since the 90's and I have never once used those two icons in the bottom right corner of the transform form. Thanks for you help, that will do what I need. Learn something new every day....
