Enable/Disable Plugin via macro
Michaelangelo631
Michaelangelo631
Does anyone know if you can disable/enable powermill plugins via macro.  For some odd reason it takes a long time on startup when trying to load my NCSimul plugin.  This is the only plugin I have currently enabled.  Once I disable this in the options and restart pmill everything opens fine and quickly.  Once pmill is running and I go to the options to enable that plugin, it enables very quickly without the long lag.  My thinking was that I would keep that plugin disabled in the settings and be able to toggle it on and off via macro as needed.  Your feedback is much appreciated.
Mike
5axes
yes with the command :
PLUGIN MANAGER ENABLE "{XXXXXXXX-XXXX-XXXX-XXXX-XXXXXXXXXXXX}"
PLUGIN MANAGER DISABLE "{XXXXXXXX-XXXX-XXXX-XXXX-XXXXXXXXXXXX}"
you just need to get the UID of the plugin via the Class ID of your PLUGIN
Michaelangelo631
Worked like a charm!  Thanks @5axes for the help.
Mike
