Edit shank
Edit shank
zfreitas
Edit shank
zfreitas
I load a tool with shank from my tooldatabase to Powermill . Then I just want to edit the shank and all fiels are locked, nevertheless I can change the cutting(yellow) part of the tool.
Can someone help me on this one? Is this a bug?
Best regards,
Jose Carlos Freitas
Tech Support Engineer
NORCAM
ChristopherMarion
Hi @zfreitas
This is the behavior of imported PowerMill tools for as long as I can remember.  It doesn't matter if you create the tool from the database or from a template, the shank and holder components are not editable.
I don't think this is a bug, but rather intended.  I just do not know why that is.
Christopher Marion
Technical Specialist - CAM
SolidCAD - Canada
kevin.hammond3WX4X
have you considered cloning the tool delete the imported one, make required edits, then use it or add to database it should update original.
