Hi
I have an 3-axis ductpost post processor that works really well.
2017 suggest I update it to the newer 2017 pmpost so I can have all
the functionality. Which I agree with. We are on Maint. so I don't think it will be a problem.
I need to know how and where to submit it and have it converted.
instrumakr
Hi
1. Run Delcam PostProcessor
2. File --> Import Option File...
3. Save Option File As...
I was a bit skeptical about this solution, but it works. !!! The code is slightly different in my case between the two programs but nothing problematic! Thank you very much for this tip @Mikhail_Voronin.
Always glad to help
but you need to very carefully compare the NC-code.
Sometime I have problems with the conversion. And I modified the post.
